E30 #2: 1990 Delphin: RHD ITB M20
  • whodwho
    • Jun 2008
    • 1547
    #271
    That sounds like a juggling act with getting it all assembled, is the plenum that hard to install/remove after where you couldn't of installed the spacers and plate first?
    Looks great in the end, have you driven it yet? It sure alters the sound
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
    • 318aye
      • Jun 2010
      • 895
      #272
      According the instructions, you can't get the carbon on/off once the once the spacer/backplate assembly is in place but I didn't test that theory. It would probably have been worth it to try it with the spacer/backplate mounted loosely on the itbs.
      Rama also has a theory that the carbon portion of the box itself may pull the backing plate out of plane a bit when it gets tightened down, which may explain why the fitment was way better when I was assembling the spacers to the backplate. This would mean you should leave the bolts securing the carbon a little loose (at least most of them) when doing the final install to keep the spacers correctly aligned. Definitely something I'll look into.
      I cranked it up for 2 seconds last night just to make sure I hadn't jostled anything wiring-wise. Sounded very deep :). Might cruise it around the block today.
      • N2MYE30
        • Oct 2007
        • 5536
        #273
        COTM
        • KrautnotRice
          • Feb 2015
          • 406
          #274
          This is so awesome, thanks for sharing!
          '93 300TE 24V Krautbomber
          '84 528e 5 speed Saphirblau Metallic [R.I.P.]
          I love all BMWs with round headlights!
          • 318aye
            • Jun 2010
            • 895
            #275
            Originally posted by N2MYE30
            See you in a few weeks! Congrats on growing a 3rd pedal.
            Thanks! Hope the info helps somebody down the road.
            • bradnic
              • Jul 2012
              • 3554
              #276
              Beautiful. and functional.
              So on to the intake and filter..
              can't wait to see this car at the vintage!
              HOWTOs:
              DB vert plastic bumpers
              OEM Keys
              MTech1 docs
              88 ix Lach/Card
              91 ic Calypso 3.1
              86 Cosmo 2.7
              OEM+ or bust!
              • CorvallisBMW
                Long Schlong Longhammer
                • 13039
                #277
                Beautiful! I'm excited to hear some vids of her running :)
                • 318aye
                  • Jun 2010
                  • 895
                  #278
                  I think I'm doing Saturday and Sunday. See you there.
                  I ran it for maybe 2 or 3 minutes this morning, definitely a change from open trumpets. Filter shows up tomorrow, I'll slap it on and take it around the block Sunday or Monday with the GoPro.
                  Sooo today I checked the hood clearance. Clayed a few areas to see where the tightest spots were, then doubled up on those. End result looks to be dead in the middle on the driver's side of the "crest", and ends up with about 3.5mm clearance on average (varies a bit front to back). See pictures.
                  I dropped in my first shot at an enclosed filter box, and it fit like most first shots do. Retaining the ABS pump AND the stock airbox bracket really kills all the cleanliness that the Castro box offers. This did show me that this method really won't work all that well. If I were to enclose the filter, it would likely have to be like the image below:
                  So now I'm really back to my first option, which was the KAMotors box. I found similar offerings when searching for "carbon fiber canister air filter":
                  http://www.ebay.com/itm/Universal-Co...-/171944634368
                  Real carbon fibre air filter canister with removable black ABS end caps. Fine, free-flowing, washable, mesh cone inside. To ensure cold air intake, mount the filter anywhere in your engine bay. 1 metre of black flexible ducting included. (supplied compressed) 2 x Stainless band clamps included 2  75mm I.D. to 64mm I.D. adapter/reducing sleeves for connection to your inlet manifold Lightweight stainless mounting band included. Filter canister size 130mm diameter x 200mm long. REMOTE CARBON FIBRE CANISTER AIR FILTER #CARBFIL
                  Unfortunately, most of these are 130mm (~5.125") and 4.5" is really going to be the limit in the space I have to work with.
                  I've ordered this guy: http://www.amazon.com/Green-Filter-7...=sr_1_1&sr=8-1
                  The lower base diameter is 4.625", which I should be able to juuust squeeze in this space. I think I'll 3D print something that will mount to the airbox bracket to retain it. The plan is to use carbon tube like the other canister boxes, but in a size that will work for me. Will print the end caps as well, and reinforce with metal. Waiting on the filter to arrive to check exact sizing before ordering the carbon.
                  Pictures:
                  • digger
                    • Nov 2005
                    • 6210
                    #279
                    this brings back so many bad memories trying to get my airbox to fit lol
                    • 318aye
                      • Jun 2010
                      • 895
                      #280
                      Don't put that evil on me . I shudder to think about making it entirely on my own if Rama hadn't gone through with it.
                      • 318aye
                        • Jun 2010
                        • 895
                        #281
                        Did more searching on off the shelf filter setups, as well as exploring my options for 4.5" ID CF tubing. I'm down to one tube shop that isn't $700, and I have two filter options. The filter I have on hand is 4.625 OD on the big end, with a 3.5" outlet (no need to step up to the 90mm inlet on the box). The other that I'm looking at (http://www.knfilters.com/search/prod...x?prod=RU-5111) is 4.5" on the nose, but only has a 3" outlet. Going to try and cram the big one into the 4.5" ID tube. May require shaving the filter a bit.
                        Made a quick model of the end cap. Looks like a $40 shapeways print, but I'll try it on a printer here locally first.
                        My end goal is basically to replicate the KAMotors intake but in a smaller diameter and length, and with an offset inlet to get everything situated correctly for this airbox.
                        Also pulled the high beam to see how much room I'm really working with. On another note, the C101 connector clearance was too tight for my taste. Ziptied aside.
                        • kamotors
                          • Nov 2007
                          • 7102
                          #282
                          looking awesome
                          7speedshop.com
                          • 318aye
                            • Jun 2010
                            • 895
                            #283
                            Originally posted by kamotors
                            looking awesome
                            Thanks, looking forward to your shipment!
                            • CorvallisBMW
                              • 13039
                              #284
                              Fitting a good filter and shield is tough, I know you're pain! Looks like it's coming along though :up:
                              • Julien
                                • 7472
                                #285
                                Awesome progress dude! I like the fact that some of this work is happening in what seems to be a southend apartment complex parking lot- lol. I did coilovers on my miata in my plaza midwood apartment building.. only got a few awkward stares. Now that I'm back in charlotte I'll have to catch up with you next autox or cars and coffee. I'm currently rocking a green turbo NA as my project and a 335i f30 daily.
                                *edit: was sad to see you got rid of the blaupunkt toronto - my favorite all time deck. Can't argue with the Manhattan, I had the same in my 325ix build
                                Build Threads:
