Looks good so far, you should find the same Bosch drivers should power the EDIS. Keith can confirm though. (this is Andrew from IE)
Build Thread: 325iC Turbo - Total Restoration
Originally posted by E34DIYer View PostOrdered a new engine wiring harness from ECS Tuning. We'll see if they actually manage to locate one...
UPDATE: ECS Tuning cancelled my order, as it was NLA in the U.S. However.... BMW of South Atlanta was able to confirm SEVEN (7) harnesses still available in Germany, so I should have one in 2-3 weeks.
Just curious how much is a new harness from bmw
Install it after the tranny is in the car. Why not piece together a turbo kit. Way cheaper. The most expensive part of piecing together a m20 turbo kit would be the manifold which would be around 1200 for a made in the USA by hand manifold. Could of gotten a almost mint harness for 120 btw. To each his own.
I thought about piecing together a turbo kit, but TCD's pricing for everything included isn't bad. Also, my project co-owner would rather spend a little more going with a bolt-on, tried-and-true solution than doing a lot of trial and error with plumbing. Our goal with this car is to spare (few) expenses and have it done with the best fit-and-finish possible.
I put together my own turbo setup on my E34 M30 turbo car, which was fun. But I'm looking forward to trying a bolt on solution this time around!
Originally posted by E34DIYer View PostI thought about piecing together a turbo kit, but TCD's pricing for everything included isn't bad. Also, my project co-owner would rather spend a little more going with a bolt-on, tried-and-true solution than doing a lot of trial and error with plumbing. Our goal with this car is to spare (few) expenses and have it done with the best fit-and-finish possible.
Get a kamotors kit. Best 2500 you'll spend.
Originally posted by E34DIYer View PostI thought about that too! Does he offer his kit with a bottom mount manifold?
I'm sure you guys would be able to work something out. Message him probably just substitute the manifold out for your own.
