I always love OEM clamps. One thing I try to save from parts cars. They just plain work the best.
M30 OEM Turbo project
Nice and tight. Have you tapped into the oil pan for turbo oil return lin?Projects Hartge,Alpina & AC Schnitzer Builds.http://www.r3vlimited.com/board/showthread.php?t=280601
DSC04926 by Raul Salinas, on Flickr
DSC03413 by Raul Salinas, on Flickr
No, and honestly I may not do it that way. There is a gang blank on the block where the turbo drains on m106 motors. All I would need to do is pull the pan and drill out that gang, and I could run the stock 3"-long rubber tube right in to the block. I think it might be easier and a bit cheaper.Comment
I'm finally getting a bit closer on the boost controller mock-up. The problem I've been having is how to route the pressure hose from the intake (pre-throttle), through the boost controller, and on to the wastegate. The port I installed on the intake pipe has a 10-24 thread pitch, and the port on the wastegate is m8x1.0. Neither of those are common, and it's impossible to find barbed fittings that will plug straight in. So I've have to spend $50 with McMaster on some crazy expensive little adapters to make it all work. I love them for their selection but hate them for their prices (I also tried Fastenal, Tacoma Screw, MSC, etc but nobody had all the parts I needed)
So it will look like this when done:
intake tube -> threaded 10-24 insert - drilled out 10-24 to 10-32 thread adapter - 10-32 to 3/16" barbed hose fitting -> 3/16" hose -> manual boost controller -> 3/16" hose -> 3/16" barbed hose to 1/8NPT hose fitting -> 1/8NPT to m8x1.0 drilled out thread adapter
Not the easiest route. If I could have bought the OEM tube, I could have cut off the end connections and just ran 3/16" hose everywhere I needed. Probably would have been cheaper too :/Last edited by CorvallisBMW; 01-28-2015, 07:39 AM.Comment
Originally posted by SpasticDwarf;n6449866Honestly I built it just to have a place to sit and listen to Hotline Bling on repeat.Comment
I've never parted a car so I don't have a bunch laying around, but I should have a good supply now :) I think I ordered 20 in total.Comment
I also got a replacement rear ashtray to replace the one that's been missing for the better part of 4 years haha
Additional things that were done: adding a bit of clearance to the radiator core support for my air filter. Quick hit with the angle grinder and touch-up paint gave me another 1" or so.
Before
During
After
FUCK FUCK FUCK. I was putting the thread adapter for the oil temp sender in to the engine, and this happened:
It broke of clean, with the threads stuck in the head
It's probably because I'm an idiot and threaded the sensor in to the adapter before putting the adapter in to the head. Since the sensor is tapered thread, it probably put extra stress on the adapter and may have caused it to fail. So, what the fuck do I do? I'm stumped. I really, really don't want to pull the head to get it out, but I don't have many other ideas. Maybe a screw extractor?Comment
Try JB welding a bolt that's the same size as the inner diameter of the brass part that broke off and see if it'll come out that way?'70 911s | '72 2002 | '88 M5 | '89 330is | '89 M3 | '95 911 | '02 M5 | '04 RR HSE
or if no room-nipple extractor
7speedshop.comComment
http://www.plumbersurplus.com/Prod/P...tractor/229167Comment
