Wannabe30's s54 swap
  • WannaBe30
    • Feb 2013
    • 295
    #46
    Thanks for all the positive words. This project is really moving along even though I feel like I haven't spent that much time on it.
    Bolted up the eBay headers today and I must say.... I wish I bought the longer studs with torx on the end and I still might. But for now i would not recommend buying eBay headers unless you like exhaust leaks.
    The nuts that came off the block with the tuds in them fit back great other than a few of the holes didn't line up .. 2 or 3 overall
    And also I couldn't get one but back on one of the studs because the headers are a lot thicker than the stock manifolds and the studs are not that long. But that particular hole on the headers the weld is actually blocking it so I will try to chisel the weld just a bit to get that nut on.
    I also plan on re torquing everything after its ran a bit hoping it will kind of line everything up itself with heat
    Also the 02 holes are obviously going to need to be relocated and I never understood why you need pre and post holes on headers when no one is going to add cats to headers???
    Also even with the lollipops the front header is touching but I will be able to bend that a bit by heating it up..
    All in all I guess you get what you pay for and I knew that going in as I have installed a different (slightly more expensive) headers on an s54 but that was in an e46 m3 and so I get not all fits are perfect.
    For 150 shipped I defiantly got what I paid for but they will work for now
    On to the few pics I took
    • WannaBe30
      • Feb 2013
      • 295
      #47
      So I've never installed an adjustable sway bar but it's there and attached. I will have to look into tweaking it the right way later. If anyone has any links feel free to share.
      Here's what it looks like
      • Jb325is
        • 2136
        #48
        You want the sway rear facing arms of the sway bar to be parallel to the ground. Once you get the height set, tighten one end link then adjust the other so that it is free (you can move it freely with your fingers), then tighten it. All of this should be done with the car on the ground.
        Sucks about the headers, but that's why I went with the SGT's. You gotta find a way to get those other nuts on, it's going to leak like hell
        - '88 m54 coupe
        <3
        • WannaBe30
          • Feb 2013
          • 295
          #49
          So parallel to the ground while sitting on the ground? Fantastic. I'll adjust that today.
          Yes I know I do i am probably going to get the longer e92 335 bolts with the torx ends and just re do it later
          Thanks jb325is
          • Andy Mechnic
            • Jan 2015
            • 117
            #50
            I can't wait to jump on this bandwagon..... everyone else is S54 swapping, why shouldn't I? :D
            • WannaBe30
              • Feb 2013
              • 295
              #51
              Well I've made a lot of progress but didn't take many pictures.
              I found some hoses that will work for the upper and lower radiator
              I mounted the expansion tank in the battery tray
              I plugged up the ecu and all the ground wires and everything except the temp sensor and the gas pedal
              I'm still waiting on the gas pedal bracket and a tap to make a new hole for the temp sensor.
              I did get the new fuel pump in
              The massive booster delete is installed with the modified pedal and master cylinder.
              I need to extend or make some new brake lines though since the master is now 3" closer to the fire wall
              All in all I'm about 80-90% and pretty much ready to start her up in maybe a week
              • ohrvik
                • May 2011
                • 11
                #52
                cool thread :)
                • WannaBe30
                  • Feb 2013
                  • 295
                  #53
                  AN lines for the oil cooler:
                  Grinding the brake pedal
                  Bracket is gone
                  • WannaBe30
                    • Feb 2013
                    • 295
                    #54
                    Been a very long time with no update but I did get it started and drivable.
                    Next stop is exhaust work. Here's a pic and video
                    https://vimeo.com/120619621
                    • Jb325is
                      • 2136
                      #55
                      Nice work!
                      I wouldn't drive it much like that, sounds like you've got a big miss.
                      - '88 m54 coupe
                      <3
                      • WannaBe30
                        • Feb 2013
                        • 295
                        #56
                        Before the maf was hooked up its a little better now.
                        • marshallnoise
                          • Sep 2013
                          • 3148
                          #57
                          Nasty exhaust leak the reason for the ticking?
                          Si vis pacem, para bellum.
                          New Hawtness: 1995 540i/6 Claptrap
                          Defunct too: Cirrusblau m30 Project
                          Defunct (sold): Alta Vista
                          79 Bronco SHTF Build
                          • WannaBe30
                            • Feb 2013
                            • 295
                            #58
                            Yeah the headers are crap quality and leaking where it mounts to the head I'm gonna have that fixed this coming week
                            Here's a cold start up this morning
                            Does it still sound like its missing??https://vimeo.com/120800660
                            • marshallnoise
                              • Sep 2013
                              • 3148
                              #59
                              You could double up on the exhaust gaskets with a thin layer of rtv between them and probably get the seal right. Then see if you have an actual miss.
                              • WannaBe30
                                • Feb 2013
                                • 295
                                #60
                                I have a miss
                                I'm outta practice I use to catch those easy.
                                Also double up on the gaskets are not the problem the header flanges don't line up with holes for the threads
