Huh. I'm not liking that your Sachs pressure plate didn't hold up, I just put one in my car. It hasn't been in the car long has it? less than 2 years? Glad you found your issue, and it's cheaper than it being the flywheel.
Bronzit E30 - OBDII S52 shaved bay - weekend/autox toy - Journey
Originally posted by ST1G View PostHuh. I'm not liking that your Sachs pressure plate didn't hold up, I just put one in my car. It hasn't been in the car long has it? less than 2 years? Glad you found your issue, and it's cheaper than it being the flywheel.
That said, when this failure occurred I was ripping on it. I was taking a turn wot with a little sideways and wheelspin and had just slammed it into 3rd I think.
Originally posted by 2mAn View PostI wonder if there is any warranty on it?
ZF Services North America, LLC (“ZFSNA”) warrants its clutch products to be free from defects in materials
and workmanship under normal use and service as hereinafter provided, for twelve months after installation in
a vehicle. ZFSNA’s obligation under this warranty is limited to providing, at no charge, a replacement for any
part of such clutch product that fails within the terms of this warranty. ZFSNA will not be responsible for the
cost of labor related to the installation of the replacement part.
In order to obtain warranty service, the entire clutch assembly, including, the clutch cover assembly, the clutch
driven disc, and the releaser along with proof of flywheel resurfacing or flywheel replacement, must be re- turned to an authorized ZFSNA distributor, with proof of purchase, work order, full particulars as to the type of
use, application, and length of service of the failed part. All returns must include proof that the flywheel was
either replaced or resurfaced.
This warranty does not cover failure or malfunctions resulting from use for high performance or racing pur- poses, accidents, improper application or installation, modification, alteration, improper servicing, tampering,
normal wear and tear or abuse.
Any implied warranties, including warranties of merchantability and fitness for a particular purpose shall be
limited in duration to the period of the time set forth above. ZFSNA shall not be responsible for incidental or
consequential damages and its liability shall be limited to the amount paid for the product. Some states do not
allow limitations on how long an implied warranty lasts or the exclusion or limitation of incidental or consequen- tial damages, so the above limitations or exclusion may not apply to you. This warranty gives you specific legal
rights, and you may also have other rights which vary from state to state. This is the only express warranty
applicable to ZFSNA clutch products; ZFSNA neither assumes nor authorizes anyone to assume for it any other
express warranty.
Looking back at my posts, it seems I installed the PP around 4/23 ~10 months ago. I am using an oem sachs clutch disc and TOB and I did have the flywheel resurfaced (I just have to find proof - I hope I kept that)
If I can find all that stuff maybe I have a case.
Just hope they don't see this thread :D
So good news, BMAparts will replace the whole kit (PP, clutch disc, TOB) under warranty through sachs/ZF. Sounded like the warranty is now 2 years, and all I had to do was send them a picture of the failure which was sent to their sachs/ZF rep and it was taken care of. I also ordered a rear main seal, trans input seal, and clutch slave. I would've picked it up today, but forgot to bring the clutch kit to work with me to exchange.
Full C25 tank gauges for my future reference.
Replaced a bunch of fasteners.
Relocated the O2 sensor bung on one manifold so it now clears the coolant drain on the block and I can install the coolant drain extension. I don't understand why that O2 bung points directly at the drain from factory.
It's always nice when a warranty works out for you.How to remove, install or convert to pop out windows
this thread is always full of win
:up:-Brad, AlphaTeam Motorwerks, LLC
91' 318iS - S54/6MT Swapped
08' E90 M3 6MT - Daily
Originally posted by ST1G View PostBad ass. Glad they took care of you.Originally posted by rzerob View PostIt's always nice when a warranty works out for you.
Originally posted by spiDmang View Postthis thread is always full of win
:up:
but thanks!! it did give me a smile
Originally posted by Sh3rpak!ng View Postmeh it depends on if you're inside looking out, or outside looking in
but thanks!! it did give me a smile-Brad, AlphaTeam Motorwerks, LLC
Originally posted by spiDmang View Postdont worry man, i know your pain. Alot of the vets have been there. But you on the other hand have taken it to a whole other level...
Sent from my SM-G920T using Tapatalk
make sher ya shmear sum blue shmoo on them flywheel n preshur plate bolts otherways youll end up like that guy KAmotorsLast edited by pandaboo911; 03-03-2016, 04:56 PM.
glad to hear that you figured out the problem Charlie!Singer Vehicle Design.
Quan@singervehicledesign.com
