Bronzit E30 - OBDII S52 shaved bay - weekend/autox toy - Journey
  • Sh3rpak!ng
    • Jan 2014
    • 2667
    #1021
    Originally posted by ZekeTheSneak
    That is a good point. Recommend a gun? Yah I've got a very large compressor already thankfully.
    Perrect, that's the expensive part. I've been using a $10 hf gun believe it or not. The more expensive devilbiss I have needs more air than my compressor can supply
    Sent from my SM-G920T using Tapatalk
    Shadetree30
    • Sh3rpak!ng
      • Jan 2014
      • 2667
      #1022
      Here's a little diagram that helps illustrate the shifter operation
      Made a bracket to mount the shifter plate
      Modded some set screws for smoother operation, then found out "ball bearing" set screws are a thing so those arrive today
      Also rounded out the end of the pin a bit again for smoother operation
      Started with some good old CAD for the ash tray panel
      And we're finished
      Shadetree30
      • kts
        • Jun 2010
        • 753
        #1023
        Please stop being so awesome. :)
        • rzerob
          • Jun 2013
          • 2315
          #1024
          That shifter surround turned out awesome. Why did you relocate the lighter?
          • Sh3rpak!ng
            • Jan 2014
            • 2667
            #1025
            hahaha thanks :)
            Thanks man. Funny story about that. I didn't mean to put it on the other side but when I marked the panel before I bent it I had it upside down and didn't realize it until after it was too late and certainly didn't want to re do it.
            Shadetree30
            • jpod999
              • Dec 2015
              • 1401
              #1026
              Watch people on IG start doing the same thing (moving the socket to the other side I mean) ;)
              OBDI M62B44/6 swap
              Transaction feedback
              - jpod999
              • Sh3rpak!ng
                • Jan 2014
                • 2667
                #1027
                bahahahaha that would make my day
                to be honest it kinda annoys me. I hate screwing up details like that. I might just cut another hole on the other side and add a second one to keep things even. I already have another socket
                Shadetree30
                • TheWipprSnappr
                  • Jul 2015
                  • 477
                  #1028
                  That looks sick. what selector rod are you using in conjunction with this?
                  1990 325iX - sterlingsilber metallic
                  1991 325i - lazurblau metallic
                  Originally posted by delamaize
                  E30 = Lego for men.
                  • wworm
                    • Dec 2016
                    • 1719
                    #1029
                    page 69!
                    1984 Delphin 318i 2 door
                    • Sh3rpak!ng
                      • Jan 2014
                      • 2667
                      #1030
                      Originally posted by wworm
                      page 69!
                      Currently a new oem e36 selector rod, but an akg dssr arrives today :D
                      Shadetree30
                      • ngampleh
                        • Jul 2012
                        • 466
                        #1031
                        Originally posted by Sh3rpak!ng
                        No torsion spring on lever?
                        Sent from my SM-A310F using Tapatalk
                        [ETA - E30 Adapters] 5 Lug kit with e46m3 front and e46 325/328i rear brake setup
                        [ETA - E30 Adapters] - 5 Lug kit | DTM Shifter | DSSR
                        Transaction Feedback
                        • Sh3rpak!ng
                          • Jan 2014
                          • 2667
                          #1032
                          Nope. If your trans is healthy it is unnecessary. I just replaced all detents, springs etc. It snaps back to position forcefully on its own.
                          Shadetree30
                          • ngampleh
                            • Jul 2012
                            • 466
                            #1033
                            Got it...
                            Thanks
                            • Digitalwave
                              is a poseur
                              • 6299
                              #1034
                              This is an incredibly detailed and inspiring build. Just got caught up on the thread. Keep up the great work!
                              RISING EDGE
                              • manneh_rahwrs
                                • Apr 2016
                                • 1
                                #1035
                                Holy crap... I've spent the last two weeks reading from beginning to end after stumbling on your thread. Everything you've done is just so clean and satisfying, and hopefully, I can put a 1/10th of the attention to detail you did into my car. So much yes... SO much yes haha ;D
