i cant get over how epic this car is.
E30 Street/TimeAttack (+ E36 V8 Turbo Touring)
WOW. I can't really put it into words of how bad ass that looks.How to remove, install or convert to pop out windows
Thank you......THANK YOU THANK YOU for doing this so right.sigpic
Instagram @rebellionforge
I love the updates to this thread, soooo great.1991 325i - "Scambles" The Daily Driven lightly modded.
1988 Mazda RX-7 TII "Mako" The Free Dorito
bacon by Jared Laabs, on Flickr
Good to see I'm not the only one who likes itTrying to keep on going and posting updates for you!
NotJesus: I've got two options, Unlimited or Modified.
Modified is for highly modified street cars and allows use of semi-slick tires. There's more drivers in this class.
Unlimited has no restrictions, but has more strict safety regulations which my car fulfills anyway, use of slicks allowed. Only a handful of drivers, in some races only two to three participants
Good God that meat1989 325i LS Swap (Money Pit):https://www.r3vlimited.com/board/sho...d.php?t=244933
COTM Feb 2019: https://www.r3vlimited.com/board/sho...d.php?t=428404
Subbing... wow.
Those tires are almost as wide as what I run on my 4.8is e53 (325/35/20)! Awesome to see so much tire on an e30."A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
91 318is Turbo Sold
87 325 Daily driver Sold
06 4.8is X5
06 Mtec X3
05 4.4i X5 Sold
92 325ic Sold & Re-purchased
90 325i Sold
97 328is Sold
01 323ci Sold
92 325i Sold
83 528e Totaled
98 328i Sold
93 325i Sold
I've heard that those anti-fog liquids doesn't work very well at Finnish weather conditions, blower or a heated windshield is a must.
One day I tried how things fit in those RF wheels, 15mm spacer is minimum to clear the caliper but with 7" inner barrel it's pretty close to damper. So maybe a 6.5" barrel would be a better choice.
As someone might ask, here's the complete list of the parts:
-E36 M3 spindles
-E46 M3 OEM rotors with aluminum hub
-Brembo ZL/ZR18 calipers
-MagnusRacingTeam control arms with roll-center/bump steer adapters
-K-sport circuit dampers with custom valving and spring rates for my car
If anyone else is interested in similar front control arm kit, I've got a few extra sets in stock.
U.S. buyers please contact dylan@neuemotorsports.com he's making a pre-order.
Scandinavian buyers please contact info@motornord.se
If located elsewhere, please contact us magnusracingteam@gmail.com
"These control arms are made for E30 chassis to accept and correct the front end geometry using E36 or E36-M spindles.
E36-series spindles are often used to get 5-lug bolt pattern, but they also have better variety of brakes and coilovers than E30-series. Spindle itself has better geometry for racing as it is closer to E30 M3 variants.
The most notable advantages are correct wheel location and roll-center/bump steer correction which are decayed when substantially lowering the car. On the side the adapter plate also makes the steering ratio quicker. Kit only has about half the weight of orginal cast control arms.
The kit offers a chance to adjust the front end the way you want it; width, caster and anti-dive properties are all adjustable.
This is pure motorsports from the E30 DTM era."
