The Malaga Bomber (no rust this time)
'73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold] -
Could be better, could be worse.Comment
Nah, I'll be running my Condor shift knob
No, just a budget built street car where an aftermarket speedometer is an unnecessary large expense.
'73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]Comment
Well hot damn..!!!! love the wheels. Keeping my eye on this build.Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
____________________________
E-mail Panayiotisx2@gmail.com
Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=ULComment
Originally posted by SpasticDwarf;n6449866Honestly I built it just to have a place to sit and listen to Hotline Bling on repeat.Comment
Thanks Otis :D
I think we all would!
Great idea. I'll probably run one of these instead of a speedo
True story, my Grandfather once drove an airplane on the road down the highway and got pulled over by the cops. He had an air speed gauge and no speedometer but that wasn't why he got pulled over.How to remove, install or convert to pop out windows
Thank you!
So, a few small updates. I just finished the last of my midterms and spring break is starting. Hopefully I'll make some decent progress now :o
To start, I finally ordered some seat brackets for the Cobras. I went with Kirkey universal ones. Looks like I'll need to extend them about 1"
My next project involved me destroying something that worked to try to make it better. The aluminum radiator I got was for a late model e30. However, after trying to run the metal coolant hose I realized that I did not have enough room to fit it between the radiator/waterpump. Faced with this problem, I figured I could just run a long aluminum pipe across the top of the motor instead of in front of it like a late model. But then I'd have a 3' coolant hose :???: So instead...... I decided to chop it up and convert it to an early model radiator. This consequently reduced the length of my coolant hoses quite a bit.
Here's pics of chopping the existing inlet/outlets off the radiator
Next I cut new holes into the end tanks of the radiator to relocate the inlet/outlet. After that I test fitted the pieces of tubing I was going to use
Then last night after dropping it off at Wot-Tech to get welded, I was able to pick it up. I'm happy with how it came out! :D
Next I test fitted the radiator hoses. Everything fits much better than before and I have a lot more room! I'll end up using some scrap pieces of tubing so I can shorten the hoses a couple inches in the middle. Other than that, the coolant system is done.
For this one I'll need to get a little creative, but it's so much better than before.
Good shit man!
I've got a Scirocco Radiator in there where both inlet and outlet are on the passenger side.
I used a late model upper hose to get from the Tstat housing to the upper rad neck (pass side).
I used the late model lower radiator hose from the Tstat housing, to the metal bypass hose from a late model, to a late model rad hose from the bypass hose to the lower rad neck. Everything fits pretty damn good! I'll take pictures when I have time this weekend, it all looks clean.
Excited to see how you finish up the tunnel! Keep it up bro, huge motivation for me. If I were closer i'd buy you a beer.
clutchCTRL!Move with a purpose.- 1991 325iX 4dr/5spd- 1976 2002 SlickTop/2.7i M20/G260- 2000 323i AT2016 Mazda CX3 Sport AWDComment
