The Malaga Bomber (no rust this time)
  • 2mAn
    SeƱior Mod
    • 20864
    #31
    yesssssssssssssssssssss
    Simon
    Current Cars:
    -1966 Lotus Elan
    -1986 German Car
    -2006 Volkswagen Jetta TDI
    Make R3V Great Again -2020
    • LoneWolf
      • 402
      #32
      Niceeeee.
      • AbsorbantNut
        Non faccio funzionare questa merda
        • Jun 2010
        • 2491
        #33
        Originally posted by LoneWolf
        Niceeeee.
        :p
        So regarding the fuel system of the car........it has a metal feed line and plastic return line stock. I replaced all the rubber fuel hose with brand new hose before I swapped the motor in. I also bent a few e30 hardlines to use as a metal return line for the car. Seeing as all the lines would be fresh and clean, there's no sense in mucking them up with all the rust that was in the tank. So instead of buying a new tank, I just used POR-15 tank sealer like I did in my e30, and I'm very happy with the outcome. The inside of the tank is rust free & sealed, and I de-rusted/por-15'd the outside of the tank as well. Along with the mounting surface in the trunk for the tank. Here's a few pics of that
        I also installed a new walbro 255 fuel pump, so technically the car has a "brand new" fuel system.
        Next I grabbed what gauges I had left from the e30 & ordered a few more from summit to begin to build a cluster
        I made a template in wood before I cut the aluminum version.
        Where do I plan on getting the aluminum to make the gauge cluster & a radiator shroud you may ask?
        From this stop sign!
        She's slowly coming together. I took it for a quick spin around the block & man is it quick
        I also installed my new shift knob, really liking the way that it feels in my hand when I grab it to go into the next gear;D
        '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
        • knuklehead92
          • Aug 2011
          • 732
          #34
          awwww yeaaa!
          Trust me it stock :yawn:
          • kid325e
            • Sep 2007
            • 6422
            #35
            Sub'ed. Thanks for pointing me this way on 2002FAQ.
            Going to read through this in a bit, at work currently but glad to see a familiar Avatar, your name was familiar over there but your AV did it. haha.
            You seem to have documented well thus far, keep it up bro! I just cut out the nose of mine but not as far as you have.
            clutchCTRL!
            Move with a purpose.
            - 1991 325iX 4dr/5spd
            - 2000 323i AT
            2016 Mazda CX3 Sport AWD
            • kid325e
              • Sep 2007
              • 6422
              #36
              The rear shift linkage "mount/bushing" is temporary right? Only reason I ask is it looks super high! I'm assuming that was done just to drive it? Man, i'm getting so antsy reading this at work!
              Which trans mount did you run?
              clutchCTRL!
              - 2000 323i AT
              • kid325e
                • Sep 2007
                • 6422
                #37
                Originally posted by AbsorbantNut
                How'd you bust your trans mount ear? Fixed now?
                This is your CSB mount bracket? How the hell does that work? lol. Thanks man.
                clutchCTRL!
                - 2000 323i AT
                • lambo
                  Captain Scene Points
                  • 10953
                  #38
                  Did you steal that stop sign? :tsk:
                  srsly tho I love your gauge setup. Should rotate your tach because HOLD STUMT
                  • AbsorbantNut
                    • Jun 2010
                    • 2491
                    #39
                    Originally posted by knuklehead92
                    awwww yeaaa!
                    Thanks bud! I see that you have two 2002s now. LUCKY!!!:p
                    Haha no prob. Yeah, I cut out a lot of the front end nose stuff to make room. It's tough squeezing in a radiator + a 3" core intercooler ;)
                    No the shifter is permanent. I used the sin city motor mounts, but as I said earlier in the thread I had a ton of issues with them. They made the motor sit high in the car, so I'm just raising the trans tunnel. The shifter feels great where it is, very close to the steering wheel and easy to reach.
                    All the bushings in the car are solid Condor Speed Shop ones
                    I accidentally smacked it with a hammer when I was underneath the car. I got the ear welded back on to the transmission, so yes its fixed. The edges bolt up to the body and sandwich the sheet metal between that bracket & some large washers on the inside. Then the top of the bracket mounts to the CSB.
                    Nah, it was included with the couch that hit my car. Thanks fam! I might rotate the tach, I keep going back and forth though. I wish I had the $$$ for a stack tach
                    Picked up this cool maglite/coolant overflow tank to use
                    I also finished the gauge cluster and ran the wiring for the lighting last night
                    Here it is mounted in the car, not sure why the coolant gauge looks like it's touching the tach, but it isn't.
                    • IronFreak
                      • Dec 2012
                      • 3702
                      #40
                      So much win in here. Really, I was wrecked when I saw the outcome of your last car. Looks like things have definitely gone in your favor. Keep up the good work man!
                      Instagram @rebellionforge
                      • kid325e
                        • Sep 2007
                        • 6422
                        #41
                        So if i'm understanding you correctly, with your CSB Mount Bracket, you've got the CSB mounted upside down compared to how it's mounted from the factory in the E30?
                        I don't have any issues with that, just want to make sure I understand you! Dude that video of it boosting is so dope. Can't wait to see what you do with the interior and transmission tunnel.
                        clutchCTRL!
                        - 2000 323i AT
                        • ThatOneEuroE30
                          • Dec 2013
                          • 8626
                          #42
                          God I love this. This really is my dream build...
                          1991 318i 4dr slick top
                          Mtech 2 turbo restoration
                          • AbsorbantNut
                            • Jun 2010
                            • 2491
                            #43
                            Thanks man, I was a little torn up about losing the e30, but like you said it led to better things.
                            No the csb mounts upright, just like it normally does on an e30. Haha thanks, its been on a few test drives so far and its quick! Im trying to keep the interior stock looking, but that's pretty hard seeing as there's so little instrumentation to begin with.
                            Thanks bud. I'm sure you'd prefer it to be m30 powered tho ;)
                            • ThatOneEuroE30
                              • Dec 2013
                              • 8626
                              #44
                              You'd thin so but no. My dream is a stripped down 2002 with turbo or alpina flare with a full cage and a m20 2.7i turbo
                              • kid325e
                                • Sep 2007
                                • 6422
                                #45
                                Okay, got it. So that runs across the bottom of the CSB? Legit, prolly way stronger then stock!
                                You work on it today at all?
                                clutchCTRL!
                                - 2000 323i AT
