Turbo M10 Build Thread, Running MS1 3.0
  • m3t4lm4n222
    • Apr 2014
    • 13
    #31
    Here's a sneak peek of the coil bracket.
    • m3t4lm4n222
      • Apr 2014
      • 13
      #32
      Here's a build log update:
      Setting up the boost controller:
      Turbo mounted, had to cut a notch out on this clean car for it to fit, but it will be patched soon:
      Oil pan off:
      • m3t4lm4n222
        • Apr 2014
        • 13
        #33
        Oil pan bung fabricated:
        Catch can came in the mail:
        Oil drain line, need a shorter fitting on the turbo side for correct drainage.
        Intercooler intake side done:
        Wideband and boost gauge setup:
        Got some wiring cleaned up:
        ATC fuse block and relay:
        • 2mAn
          Señior Mod
          • 21040
          #34
          Im going to have to pick your brain when it comes to wiring my own... Love it and keep it up. Sucks you had to notch the frame rail though
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          Make R3V Great Again -2020
          • m3t4lm4n222
            • Apr 2014
            • 13
            #35
            Especially with how clean the body was... He refused to get a different manifold or a smaller turbo. 2Hardcore for that. Replacement metal will be welded in.
            • Dj Buttchug
              • Jun 2010
              • 7688
              #36
              not sure if this is going to be a big deal but you may have oil drain issues with a super short line placed relatively low like that.
              Turbo M42 Build Thread :Here
              Ig:ryno_pzk
              I like the tuna here.
              Originally posted by lambo
              • m3t4lm4n222
                • Apr 2014
                • 13
                #37
                Yep, well aware, it will be changed.
                • Dj Buttchug
                  • Jun 2010
                  • 7688
                  #38
                  Id try it out and see first. You might be able to run a restrictor in the oil feed line and slow the flow. Some turbos require a oil restrictor, others dont.
                  Sick build
                  Ig:ryno_pzk
                  • m3t4lm4n222
                    • Apr 2014
                    • 13
                    #39
                    Sick build
                    A response from my brother:
                    ""The restrictor is on the turbo already, came with the oil feed line."
                    So I guess there's already one. He is however worried about the fitting on the turbo causing some issues.
                    • ak-
                      • 12422
                      #40
                      You couldn't clock the turbo so it points downward instead of upward?
                      A 45* drain fitting and some hose will make that drain work. Doesn't have to be AN.
                      1991 325iS turbo
                      • m3t4lm4n222
                        • Apr 2014
                        • 13
                        #41
                        Not entirely sure if he can or not, i'll see if I can get back to you.
                        • LegoTheBimmer
                          • Feb 2015
                          • 68
                          #42
                          My intercooler is behind the grille, would have to run insane piping for it to work, also my turbo is close enough to the ground... Test fitted the turbo clocked down, the coupler and pipe would be in a bad spot.
                          Soon to be turbo'd M10. Safari Beige Goodness :devil::devil:
                          (00=[][]=00)
                          • m3t4lm4n222
                            • Apr 2014
                            • 13
                            #43
                            Turbo side charge pipe done, maybe a bit more tweaking needed:
                            More wire stuff:
                            • LegoTheBimmer
                              • Feb 2015
                              • 68
                              #44
                              Just a quick non-visual update. The Bimmer should (Needs) to be completed and up and running within the next-month as I plan to drive it from Kansas to Washington State.
                              (00=[][]=00)
                              • thebutterson
                                • 463
                                #45
                                Can you post a picture of the back of your coil mount and how its mounted to the valve cover?
