E30 M3 Russia
  • Maksim
    • Mar 2014
    • 31
    #76
    привет Димон)
    • punnzzells
      • Aug 2005
      • 335
      #77
      Wow! Just amazing on how you have saved a piece of BMW history!
      I think that's the best way to do it.... if you're going to fix it, fix it properly and don't cut corners - which you haven't.
      AWESOME! * two thumbs up *
      • Dmitry
        • Mar 2015
        • 66
        #78
        Footrest:
        welding done.
        Final adaptation is on the way.
        Looking for galvanics
        • Dmitry
          • Mar 2015
          • 66
          #79
          Did not write for a period of time. Nothing significant happened. Was busy with small things (installed sunroof, BC calibrationg...)
          Also installed the armrest. In order not to drill the body, I used 3 mm steel stripe to create the mount.
          Appeared to be very solid and comfortable set up.
          • archie
            • 5448
            #80
            Beautiful! Best of luck with your M3.
            88 M3 Diamantschwarz
            89 M3 Zinnoberrot
            56 Isetta
            LIKE ARCHIE'S on Facebook!
            • Dmitry
              • Mar 2015
              • 66
              #81
              thanks! try to do my best
              • Dmitry
                • Mar 2015
                • 66
                #82
                yesterday photo:
                • Dmitry
                  • Mar 2015
                  • 66
                  #83
                  Would appreciate if you can advise on the front weel: do you think it seats correctly in the arch? To me it is a little bit backward. Some say that I can move the forward using excentric rubber bearings.
                  But first I would like to know if this is OEM set up. My car is from 1986, with standard rubber bearings and arms.
                  Thanks
                  • NZM3
                    • Jun 2010
                    • 48
                    #84
                    Hi,
                    Front wheels are meant to be back in the front wheel arch that is original and the way they all are looks slightly strange but it is correct.
                    • Dmitry
                      • Mar 2015
                      • 66
                      #85
                      Originally posted by NZM3
                      Hi,
                      Thanks. I am also coming to this conclusion, looking at the number of M3 pictures in the Internet
                      • Dmitry
                        • Mar 2015
                        • 66
                        #86
                        But still questioning: is it worth swapping the bushing for excentric from the 2nd generation? Or it is bad for suspention and steering rack?
                        • kronus
                          • Apr 2008
                          • 13032
                          #87
                          It's not bad for anything, they are a common upgrade item that increases caster and high-speed stability.
                          cars beep boop
                          • Dmitry
                            • Mar 2015
                            • 66
                            #88
                            Originally posted by 5Toes
                            wow you are doing very fast high quality work thats awesome!
                            who painted the car?
                            Sorry. Missed it. The car was painted by the same guys, who welded and iceblasted it. For sure, they have a dedicated person who does only painting )
                            The color is DiamantSchwarz Metallic
                            The paint is from Standox, the ppolish is from 3m Lasurit.
                            • Dmitry
                              • Mar 2015
                              • 66
                              #89
                              Thanks!
                              • Dmitry
                                • Mar 2015
                                • 66
                                #90
                                Thanks.
                                For the moment decided to leave it as it is, as now I am convinced that it is original set up. This is not a race car so it does not mean to much how sharp can be the turn it supports.
