☆From Sewer to Best Ever☆ E30 M3 Sport Evolution -CONVERSION- + 740i e38 MY NEW LOVE!
  • Jony
    • Mar 2014
    • 153
    #136
    Just replaced dualmass fw (e39 m5 oem) to TTV racing m62 lite lightweight fw and it doesn´t crank !only fire
    • Jony
      • Mar 2014
      • 153
      #137
      It's been excruciatingly , I bought a new lightweight fw for the m62b44 and it didnt starts. Previously there was oem dualmass FW e39 M5 and starts right. problem with CPS now we have solved. BUT, the trigger wheel is different. I can't understant that. Why it starts with different fw and now it dont. Can someone explain it?
      • Jony
        • Mar 2014
        • 153
        #138
        • fratepedia472
          • May 2011
          • 4
          #139
          Definintely respect your attempt/dedication to the engine swap. Most ppl underestimate how involved it can be especially dropping in a monster v8. when you say the trigger wheel is different, how different is it? as long as your cps distance is okay it just looks for the gap in the trigger in relation to the cams. Is the flywheel the only thing you've changed since it was running before? why not just put the m5 flywheel back in? lol
          as for not making vacuum... this doesn't make sense, every engine should have vacuum, unless u have a huge leak somewhere, have you tried hooking a gauge up to it to get actual numbers? also how solid is the engine compression wise?
          parts do fail believe it or not, definitely double check all ur wiring, grounds are super important too don't over look those straps.
          like i said swaps are very involved, if ur feeling burnt out, try and get the car on a test drive, safely of course, that might rekick ur passion for the swap. good luck bro, ill sub.
          (looks much smaller in the picture because of the angle).
          • Jony
            • Mar 2014
            • 153
            #140
            first of all I thank you very much for your opinion.
            so trigger wheel, i don´t know exatly whats the difference, i think distance between teeth. CPS distance is now correct, but as you can saw on video it shots flames only. We are absolutely certain that everything Work exept this new flywheel.
            The reason why i changed FW is that stock dual mass FW was already worn (made strange noises) and new FW is almost 16kgs lighter than oem dualmass. And of course i want some extra power and LIGHTER engine ;);)
            I am going to hit the road with my car couple months, but still fail. I REALLY HOPE that i find someone who can remap or calibrate CPS for this new flywheel and adjust ignition time.
            • E30stan
              • 658
              #141
              You are gonna want to upgrade the master cylinder to push more fluid to the bigger front and rear calipers. I suggest the 25mm from a 7 series. just make sure the booster and master cylinder are same manufacturer, Girling/girling or ate/ate.
              • Jony
                • Mar 2014
                • 153
                #142
                I have new master cylinder and brake booster from e38 740iL. But brakes issue must wait. Half issue is that engine doesn't crank with new lightweight flywheel
                • Jony
                  • Mar 2014
                  • 153
                  #143
                  TTV Racing flywheel
                  As i mentioned, i bought lightweight flywheel from TTV Racing company. We solved CPS issue, now sensor has good distance from trigger wheel.
                  This fw has only 6.9kilograms. I don´t want be negative, but i am really dissapointed with this flywheel. I did not except that FW specific for my engine won´t work :(. As you can saw video. PLEASE HELP ME SOMEONE WHO HAS EXPERIENCE WITH THIS ISSUE.
                  • delamaize
                    • Nov 2013
                    • 1463
                    #144
                    Gonna ask the stupid questions, because it's always something stupid that causes the issue.
                    Have you tested and checked the CPS?
                    Have you checked the wiring to the CPS, Especially the plug and terminals?
                    Are the teeth on the sensor wheel the same distance apart, and same size?
                    Is the CPS lining up with the teeth correctly? In other words, is the sensor in the right position front to back?
                    I have not had THIS issue, but I have had issues with vehicles being in a no-fire situation, because of those things.
                    Dumpster Fire Pilot
                    • Jony
                      • Mar 2014
                      • 153
                      #145
                      Yup! Everything you mentioned. But what do you mean with right position ?
                      • z28
                        • Oct 2014
                        • 362
                        #146
                        Keep your head up and don't give up, you will get through it.
                        First e30 - 1991 318i 4 door
                        • Jony
                          • Mar 2014
                          • 153
                          #147
                          NEWS:
                          we are sure, that fw has different trigger wheel, so it was waste of money. Bad flywheel equals bad ignition, it sparks when valves are open and it equals that it only backfire. The isn´t another option like change FW back to dualmass. TTV doesn´t report me.
                          • LJ851
                            • 7919
                            #148
                            Does your new lightweight flywheel have a locating dowel to locate it correctly on the crank? As in it can only bolt on one way?
                            Is it possible you have bolted the flywheel on at the wrong angle thus putting the missing trigger teeth in the wrong place?
                            Lorin
                            The M30 is God's engine.
                            • Jony
                              • Mar 2014
                              • 153
                              #149
                              Is it possible to bolt flywheel on wrong angle?
                              • delamaize
                                • Nov 2013
                                • 1463
                                #150
                                In theory, if their isn't a locating dowel, or if the bolt pattern is symmetrical, they you could possibly get it installed at the wrong angle, like if the TDC gap is suppose to be at 3 o'clock, but without the dowel, or a unique bolt pattern, it could possibly be bolted on, so the TDC gap is at a different spot.
                                That could cause this issue. But that is also assuming that the flywheel is not doweled, or their isn't a unique, non-symmetrical, bolt pattern.
                                Dumpster Fire Pilot
