☆From Sewer to Best Ever☆ E30 M3 Sport Evolution -CONVERSION- + 740i e38 MY NEW LOVE!
  • FreedomM3
    • Aug 2015
    • 191
    #121
    Nice! Keep up the good work!
    Our RestoMod Diary!
    El Mustache De La Resistance!
    • Jony
      • Mar 2014
      • 153
      #122
      I am really dissappointed of this build, i am angry and confused! such as small piece separates me that i will make first run with that f*cking car... it isn´t braking! F*uck that! i run 4 piston brembo calippers on each axle with such big vented rotors, so for WHAT? i decided to find problems! everything was OK! Brake system flushed with machine BUT THE PEDAL IS STILL SOFT:-x !!!! OK i try to change brake booster! If it won´t brake properly, and pedal won´t be hard i will burn that crap!!!
      second shit is that engine doesn´t make vacuum, and i dont know WHY!!!!
      P.S. oh... there is still a lot of little problems... little problems wich can´t do a first run!
      • kensol20
        • Jul 2013
        • 99
        #123
        So quick question are you running stainless steel brake lines or the stock brake lines?
        Sent from my SM-N920P using Tapatalk
        • FreedomM3
          • Aug 2015
          • 191
          #124
          I had that problem once. I turned out whoever assembled the calipers had put the end wrong and had both of the bleeders pointing the same way. Apperantly no Bueno.
          Our RestoMod Diary!
          • Jony
            • Mar 2014
            • 153
            #125
            I have OEM brake lines for a while. But i think that master cylinder is wrong. I will try to repair it, but i won't good that i dont know
            • Jony
              • Mar 2014
              • 153
              #126
              ...because when i disconnect rear brake lines and push the brake pedal, the brake fluid only leaking from lines.
              • Kershaw
                • 11822
                #127
                this is a serious amount of work. nice job. im sure you'll resolve your braking and vacuum issues.
                when you say it's not making vacuum, do you mean it has a vacuum leak?
                AWD > RWD
                • Jony
                  • Mar 2014
                  • 153
                  #128
                  Sorry i don't know to explain it because my english isn't good. But all i know is that for example when i disconnect vacuum hose from fuel press regulator (during idle) nothing happens. I dripped in one place and it would have sucked drops, but nothing... and brake booster vacuum hose is with the same issue
                  • Jony
                    • Mar 2014
                    • 153
                    #129
                    So after a few weeks, the car is not working. CPS still has bad position. It starts very heavy, and starter sparkling. so i should buy new starter, but i dont have any money and energy to tackle that junk. i spent on this about 4k euros and that car still not working!
                    peace.
                    • kensol20
                      • Jul 2013
                      • 99
                      #130
                      peace.
                      Some things take some time i sure you will get everything up and running in time .just save up and tackle it when your ready
                      • Jony
                        • Mar 2014
                        • 153
                        #131
                        thank you for your support, but i am totally tired of everything! just thinking about sell it
                        • kensol20
                          • Jul 2013
                          • 99
                          #132
                          Don't do it there was to much work put into and you wouldn't get the amount of blood sweat and tear put into it. Plus i have enjoyed seeing this come to life
                          • Fsnow
                            • May 2015
                            • 184
                            #133
                            Don't give up now! You're so close and I'm sure you will figure it out. Major projects take time and patience.
                            1991 318is x 2 .
                            • 2mAn
                              Señior Mod
                              • 21029
                              #134
                              Every major project will hit hiccups like this, hang in there
                              Simon
                              Current Cars:
                              -1966 Blue Boat
                              -1969 Red VW
                              -1986 White BMW
                              -2006 Green Thing
                              Make R3V Great Again -2020
                              • Jony
                                • Mar 2014
                                • 153
                                #135
                                Merry christmass everyone from Slovakia :) We bought bmw i8 for dad. its little car for kids :D but he really likes i8. I hope you had best christmass:p
                                Do not forget about me someday be back with news about my car. In the moment I do not do it for nothing, I have to mentally relax and then plunge into the pile of problems.
