1990 325is restomod project aka "Klaus"
  • Staszek
    • 2533
    #196
    Now that is a fill and drill!!
    • Staszek
      • 2533
      #197
      Finally did a little this weekend, pulled the front hubs off and replaced them with brand new hubs and bearings. I cleaned up the dust shield a bit which I realize I may have to trim a bit for the new brakes. I test fitted the rotor. Next step will be to install the new calipers and pads.
      The old rotor set screw was so rusted and stripped I couldnt get it off so I removed the entire hub with the rotor attached.
      All off, and yes the PO painted not only the calipers blue, but the rotor hats as well.
      Forgot to buy new dust caps, they are on the way. I still have to torque the nut down and bend the tab in.
      [/url]
      And a little test fit of the caliper, just held up for now.
      • Staszek
        • 2533
        #198
        Bought myself a present today. I already had one but it only went up to 150ft pds. This one will go up to 300ft pds
        • Helical
          • Mar 2017
          • 42
          #199
          I like where this is going!
          • sonomabimmers
            • Dec 2015
            • 802
            #200
            Just read all this, WOW. Bringing new meaning to B(rought)M(y)W(allet)
            i love bmws
            • Staszek
              • 2533
              #201
              Shhhh just dont tell my wife lol!! She loves all this stuff an was the one who pushed me on the red calipers, she just doesnt know what it costs:)
              • paynemw
                • Dec 2015
                • 439
                #202
                those wheels by that NC crew are SO clean! and clean work man!
                • Staszek
                  • 2533
                  #203
                  Question on bolt direction for the BBK.
                  I know the instructions said for the ones that bolt to the OEM caliper brackets you put the bolts through so the nuts are on the back side (closer to the engine instead of the rotor).
                  As for the ones that go from the bracket to the actual caliper, logic to me would say they would go in the same direction with the nuts on the back side close to the engine.
                  Although I saw a pic of it the other way, they work in either direction, so I guess it doesn't make too much of a difference but I would like to do it right.
                  Pic for reference, I put one on one way and one on the other to illustrate.
                  This is the pic of someone else's install with their bolts the other way.
                  • bradnic
                    • Jul 2012
                    • 3552
                    #204
                    If put the head end on the caliper - more surface area to grab. Let the nut sit on the bracket
                    HOWTOs:
                    DB vert plastic bumpers
                    OEM Keys
                    MTech1 docs
                    88 ix Lach/Card
                    91 ic Calypso 3.1
                    86 Cosmo 2.7
                    OEM+ or bust!
                    • Staszek
                      • 2533
                      #205
                      Thats what I thought, not sure why the other person did it the opposite way.
                      • Staszek
                        • 2533
                        #206
                        Some goodies came in today.
                        • Staszek
                          • 2533
                          #207
                          Got the other side wheel bearing done and mounted both front Calipers. I havent switched over the brake lines yet, I will do that this weekend.
                          In the mean time I for some reason wanted to change my radio, nothing wrong with the one I had, I just wanted buttons!! I sold the old one on the board this morning, LOVE that panjo is gone or it would have never sold.
                          Anyway I havent pushed it all in and closed it up yet but here is the new headunit, I got the colors pretty close, in this new one you can use an App to dial in the colors basically infinitely. When I get a change I will play with it more.
                          • bradnic
                            • Jul 2012
                            • 3552
                            #208
                            nice. I had the same pioneer audiquattrot uses in his IX. switched back to the IR slider CM5908 radio and added jaysterling's BT board. OEM FTW!
                            so glad panjo's gone.
                            HOWTOs:
                            OEM Keys
                            MTech1 docs
                            88 ix Lach/Card
                            91 ic Calypso 3.1
                            86 Cosmo 2.7
                            OEM+ or bust!
                            • Staszek
                              • 2533
                              #209
                              I thought about that but my OEM wiring was all cut up in the car, so I ran all new wires and RCAs to the trunk before I put in the new carpeting, I wanted to take advantage of that.
                              This one was much closer then the other one, so I am happy with it. Although one day I may black out the knob:)
                              • Staszek
                                • 2533
                                #210
                                Status Gruppe Headers came in!
