Ok I hate when I don't know something.
I believe to use the E46 PWM module for the front AUX fan:
X60004 to MSS54/HP
Pin 4: Signal to PWM module
Pin 38: Ground from lower rad temp sensor
Pin 39: Signal from lower rad temp sensor
PWM Module:
3 Wire side Blue/Red/Black
Blue: Signal from X6004 Pin 4
Red: +12V (not sure if switched....but most likely yes as I don't think it has the ability to run after power off as the DME is switched power) (12 guage wire or larger)
Black: Ground
2 Wire Side Black/RED
Black to fan
Red to fan
Garry's CAN Box:
Pin 2: AC Pressure Sensor Pin 3
Pin 1: AC Pressure Sensor Pin 2
Pin 6: Ground and to AC Pressure Sensor Pin 1
Since your using the PWM fan (WOOT!) you can control the duty cycle in regards to temp with:
And how that duty cycle is applied at speed:
Meaning at 120km/h whatever temp you are at, the duty cycle will be halved (E46M3). Above 140km/h the fan will be off no matter the temp.
X60004 to MSS54/HP
PWM Module:
Black: Ground
Black to fan
Red to fan
Garry's CAN Box:
PHP Code:
KL_ELU_TKA E46M3
Operation/speed (%)
49°C 0%
50°C 30%
70°C 40%
80°C 65%
85°C 83%
90°C 100%
PHP Code:
KL_ELU_TKA Z3M
Operation/speed (%)
39°C 0%
40°C 33%
60°C 49%
70°C 65%
80°C 83%
90°C 100%
PHP Code:
KL_ELU_V E46M3
0 km/h 1
50 km/h 1
100 km/h 1
120 km/h 0.5
140 km/h 0
200 km/h 0
PHP Code:
KL_ELU_V Z3M
0 km/h 1
50 km/h 1
100 km/h 1
150 km/h 1
200 km/h 0.5
255 km/h 0
