Lira (euro DS mtech II 318is reshelled, 24v swapped, also now BAR'd)
  • ohthejosh
    • 4963
    #91
    How long is the process for the BAR to inspect and decide?
    SO MUCH MORE TO DO!!
    IG: ohthejosh
    LEGIT CHECK ME BRUH
    BUYER FEEDBACK THREAD
    • kronus
      • Apr 2008
      • 13017
      #92
      it took maybe 45 minutes for them to go through everything. In an ideal situation, they give you the sticker/certificate at the end of this process and you can go to the DMV and register if you need to.
      cars beep boop
      • delamaize
        • Nov 2013
        • 1430
        #93
        And shit like this is why I'm glad that I don't live in commiefornia, and I live in a no-emissions county...
        Dumpster Fire Pilot
        • kronus
          • Apr 2008
          • 13017
          #94
          hmm.
          cars beep boop
          • kronus
            • Apr 2008
            • 13017
            #95
            couple new things here.
            spliced and wrapped the radio harness. The late 318iS harness is awesome and doesn't have a fader, so this was probably the least fiddly radio connector splice I've done.
            popped in the Kenwood KDC-252U. No-frills but decent head unit, I have two more in other cars.
            cleaned the block some. a lot. my wrist hurts.
            got new pulleys and a tensioner, since the old ones were making noise
            pulled the driver's seat apart to fix the tearing lower cover
            the shocks were a bit broken.
            lower cushion off
            these held the cover to the foam pad.. I don't think they'll go back in easily, so I'm wondering what else I can do. glue seems like it won't be totally secure.
            this guy (which holds the seatback up) is held on by a rivet, and frequently comes loose or cracks in half. this specific one has already cracked and been welded back together in the past, but now the rivet was loose.
            the other side had already been spot welded to the upright to hold it more securely, so I decided to replicate this.
            so, recline mechanisms off
            bag it up
            sandblast the place we're welding
            spot weld and grind!
            paint and put functional shocks back in
            the cover is off to my upholstere...girlfriend to stitch in a new panel I salvaged from a rear seat.
            cars beep boop
            • 2mAn
              Señior Mod
              • 20189
              #96
              hopefully 2016 we will both have our E30s with CA plates
              Simon
              Current Cars:
              -1966 Lotus Elan
              -1986 German Car
              -2006 Volkswagen Jetta TDI
              Make R3V Great Again -2020
              • kronus
                • Apr 2008
                • 13017
                #97
                some good news and some bad news
                good news: replaced the torn seat panel with part of a rear seat! everything is back together. It's not perfect, but it's better than it was before, by a lot.
                also did the front suspension rebuild. control arms with new lemforder balljoints, new THR-type CABs, cleaned up and reconditioned some other stuff I had lying around.
                The green springs are Weitec, which appear to be more common in Europe than the states, we'll see how good they are.
                CA's in
                Car back on the ground with its sister
                now, for bad news, here's part of the m50's chain guide
                now I have to take it even further apart :(
                cars beep boop
                • 2002jm
                  • Sep 2005
                  • 2062
                  #98
                  those cars are nice
                  Wish I had your shop!!
                  Cars look so nice. Will be looking for information on the white one; I am trying to build one too....white 87 mt1:)
                  jm
                  • kronus
                    • Apr 2008
                    • 13017
                    #99
                    i've got a whole project thread for it ;)
                    cars beep boop
                    • 2mAn
                      Señior Mod
                      • 20189
                      #100
                      that stupid motor... wtf is going. I dont think this car wants to have a 24v motor... or one of the M5x variety
                      Simon
                      Current Cars:
                      -1966 Lotus Elan
                      -1986 German Car
                      • kronus
                        • Apr 2008
                        • 13017
                        #101
                        I think it heard talk of maybe receiving the S50, and is now throwing a tantrum because it wants it over the pedestrian M50. Little does it know...
                        cars beep boop
                        • kronus
                          • Apr 2008
                          • 13017
                          #102
                          this whole time I've been storing the donor in a out-of-the-way spot in the shop, but I finally got sick of it and figured out a way to junk it. This involved trailering the shell to the DMV and annoying them until they gave me a junk slip, which took about 4 hours and the support of a very gracious DMV employee who also liked e30s.
                          Now, back to Lira and her stupid-ass motor. To get at the timing rails, you have to take off the front timing cover. It was actually a pretty easy job with the head off, the only problems being the crank bolt and the 20-something screws holding it on.
                          cover on:
                          cover off:
                          exhibit A, chain guide with the teeth cracked off
                          exhibit B, chain tensioner rail that took a faceful of chain at some point
                          exhibit C, sadface mcbrokey
                          With the rails replaced (side note, get the correct rail for the year of your motor. M50tu's had an update in early 1995 that replaced the metal-and-plastic rail with an all-plastic one, and they do not interchange easily), it was time to get the rest of it together.
                          The cover went on with new gaskets, but doing the crank bolt alone was a challenge. I ended up doing it with the car in 5th gear, using
                          some bolt goo
                          a tire prop
                          and an "extended" torque wrench
                          and then it was on. 410Nm baby, yeah!
                          for getting all the timing cover and pulley bolts in properly I like to use a mirror at a 45 degree angle to see what I'm doing.
                          pulley bits all assembled with a new idler, new tensioner, and a power steering pump that's hopefully not fucked..
                          head on
                          trays in
                          at this point I discovered that my exhaust cam was pretty scored up, got annoyed and went home.
                          the next day, wh33lhop came over with his old M50 cams and we got them in, timed, the vanos installed, and most everything else assembled.
                          The last thing remaining is the wiring harness, which I'm installing tomorrow. It's all labeled so it should be a 20 minute affair. Then we'll see if I managed to fix anything by rebuilding the top end and blindly replacing random parts!
                          cars beep boop
                          • ian e30 318is
                            • Mar 2007
                            • 1806
                            #103
                            Awesome!! Would love to stop by again to see this in person.
                            1991 LS1 Swapped 318is
                            Instagram:
                            https://instagram.com/saltybeast/
                            LS Build Thread:
                            https://www.r3vlimited.com/board/for...s-e30-ls1-swap
                            • 325ix
                              • Aug 2009
                              • 7783
                              #104
                              I have a real love/hate relationship with style 10s. In this case I love them.
                              • kronus
                                • Apr 2008
                                • 13017
                                #105
                                come by anytime! shoot me a pm
                                they're getting swapped out for a set of something neat once I have the time to refinish the something neat. in the meantime they're growing on me a bit..
                                cars beep boop
