Here is the project videos in youtube about that engine removal and disassembly I told in previous post:
e30 316 build x2 (m52/m50, turbo, 3pcs bottle caps etc)
Are the normal timing marks on the m54b30 cam still available when timing an m50b25 with that cam? Also shouldn't you use both m54 cams as they are both an upgrade instead of using only one?
Using only one high lift/bigger duration cam on the intake makes me think it's better for emissions because the exhaust gasses get re burnt.
Originally posted by iloveshaorma View PostAre the normal timing marks on the m54b30 cam still available when timing an m50b25 with that cam? Also shouldn't you use both m54 cams as they are both an upgrade instead of using only one?
And for Pazi: Great job with this car!
You're a god damn scientist. Incredible work both repair and modding. One of the best build threads I've read. Keep it coming!91 318is M50 swapped
05 Honda Pilot
24V swap thread
Using only one high lift/bigger duration cam on the intake makes me think it's better for emissions because the exhaust gasses get re burnt.Originally posted by Skarpa View PostM54 intake cam in M50 or M52 can be timed using the normal timing tools. You cannot use M54 exhaust cam on single vanos engines because the cam is for vanos. He has M50 intake cam installed as the exhaust cam. It has the same specs as the M54 intake cam and has a bit more duration and lift than M54 exhaust cam. It requires machining a little to correct the chain line and needs to be timed with a dial gauge.
Originally posted by dishwab View PostBoth builds are absolutely amazing, really fantastic work especially with all of that rust!
It makes me happy to know that even someone who has the ability to do this level of work can still make a silly mistake like forgetting to oil the diff.Originally posted by Coyote_ar View Postwow ... just wow ... amazing build.Originally posted by Nick_S View PostYou're a god damn scientist. Incredible work both repair and modding. One of the best build threads I've read. Keep it coming!
Love your cars. I stumbled across your youtube channel a while back, when you started to take apart the turbo. Everything looked really familiar, but it took me a while to figure out it was you.
Not sure how expensive shipping or exchange rate are, but you should be able to pick up a good set of s50us/S52 cams for $350usd if you try hard enough.
Edit: I was the guy who was asking about what boost you were running with stock headboltsOriginally posted by priapismMy girl don't know shit, but she bakes a mean cupcake.Originally posted by shamesonUsually it's best not to know how much money you have into your e30
Originally posted by Northern View PostLove your cars. I stumbled across your youtube channel a while back, when you started to take apart the turbo. Everything looked really familiar, but it took me a while to figure out it was you.
Whole s52 engine would be nice, because in Finland you are not allowed to fit euro s50 to non-M e36 or e30. But s52 would be ok when lied that it's m52b28 or even don't tell that you have swapped the m50/m52 engine :D
About those stock head bolts, I just remembered that guy in Finland got 636hp from his m50b30 using stock head bolts and stock headgasket (with custom fire rings made from mig wire). So the stock head bolts should hold for my use.
Here is one video of that car:
And in car video with older bit less powerful engine:
Originally posted by econti View PostIn for next video!
The process with the car is bit further than is shown in he video.
To get thew new bigger tires to fit with the e36 struts we needed to bring the wheel to the center of the wheel arch. To achieve that we changed the front wishbones to e36 M3 3.2 (EURO) ones. With those the wheel moves few centimeters:
Rear bushings are still from M3:
I replaced the shitty wideband lambda connector from KDFI port with straight wires to the Bosch LSU 4.2 connector to get the lambda work more robust. Also added wires for electronic boost controller and launch control. The third one is for extra digital input for future mods.
And now the car looks like this:
We will assemble the car to that point in next video which should be out next week so tune in.
Small update before next video. The ONE is now in driveable condition and has somekind of tune that it can be driven around. Also we needed to get the thing legally registered to Finland and to do that we needed to have dyno proofs that the car has less than 204 Hp at the crank with 0,5 bar of boost. Easier said than done because it made 310 Hp with VERY mild ignition advances with 0,7 bar of boost. But eventually we got the wanted result and the car is now legally registered to Finland with the turbo. Next we need to tune the car more and in next moth we will got to the dyno again and get the real results.
Here is one video from the dyno: https://www.instagram.com/p/BFTRzesn...en-by=sipasema
And some testing:
The 3.15 rear end ratio seems to be way too short. We will hit the rev limiter at ~220km/h with fifth gear so standing mile pulls are no go with that ratio.
Originally posted by Rocla View PostHoping to see The ONE at Saturday.
Correction, 28.5
