FreedomM3's RestoMod Diary - 89 325i
Very nice progress!! How do you like those spacer/adapters? I was eyeing them a while back as a cheap/easy way to do 5 lug if I found wheels that I liked.
I also used the same meguiars 205/105 combo on mine with a PC random orbital. The results were great like yours at first with a coat of sealant on top, then started to slowly dull. I recoated with sealant that helped, but I think my clearcoat is just dead :(
Keep up the good work! Looks great so far!!Comment
I like the adapters, however I dislike when I called trying to get torque specs and install instructions I couldn't get any, lining up the kidney is easy ( when it's loose) however when you torque it down to spec, it's near impossible to keep it from moving. The tolerance is so tight if it moves a hair I can't slide the afapter on. It's quite a pain, specially if you will be removing anytime soon. It's not really a cheap alternative, $400 new however it is quick. I wanted to keep 4 lug but I wanted the style 5s as the street wherls so it's what I had to do.
Right now I'm on the fence about what I'm doing suspension wise and possibly going 5 lug.
My clear is shot, it looks a ton better in overcast. In direct light you can still see a lot of cracking underneath the surface.
Thanks!Comment
So somethings have changed and I'm selling my suspension setup. If you are interested LMK!Comment
Since you are selling that is all moot but I did want to make that info known.
What setup will you be using?Comment
Thanks guys! The e90 hats actually settled well. I havent tinkered with the car since the last update.
However, I am waiting for the title to come in, I ended up having to bond the title from the previous owner. Long story short. The car is going to be for sale, as currently setup. I ran into an opportunity and I took it.
It is E30 related so I will make a new thread once I get some progress going. Still looking for a good early model chassis for it.
Thanks again guys!Comment
Interesting. Looking forward to your future plans
Sent from my SM-G920T using TapatalkComment
Good things happen to those who wait (c-pillar)
E30 Oem M3 Sheet metal conversion build
http://www.r3vlimited.com/board/showthread.php?t=308422
https://instagram.com/jburnsbmw/Comment
Great thread. Small world. I pass by this car all the time. My friend talked to the owner. According to him its a salvage car. The color is polaris silver. I wanted to get it as a parts car for my polaris car.Comment
