I found out later that the hub rings should have been included with the order but I checked all my boxes and they were nowhere to be found, Fifteen52 quickly sent me a set as soon as I contacted them about it. Just got home and found them at my doorstep about 15 minutes ago actually! They look great on your car! Been anxious to see these on an E30, what size tires are you running? Have any more pictures of the fitment? I'm planning on rolling my fenders all around. I was considering a 5mm spacer in front and a 15mm or 20mm spacer out back.
The Adventures of Golden Boy, my Rebound E30
205/50/r16 BF Goodrich Sport Comp 2s.
Glad you got that sorted out.
Hmmm... Don't really have any photos that show how well they line up with the fenders, but I'll snap one in the next few days if I remember.
diamantschwarz 1991 318isComment
Made some progress on the sport seat refurb today. Got the passenger side done! The lower bolster skins seemed to fit pretty loosely compared to the upper ones, so I asked my shop neighbor for some advice and he told me to wrap some 1/2" foam around the bolsters to fill the empty space, so that's what I did:
Wasn't sure how it was going to turn out because I didn't really know what I was doing, but it ended up working out fine for the most part. Got it all back together and am really happy with how it turned out!
Just as a comparison, here's the passenger's side seat right after I pulled it out of the car. It was in good condition actually, but I'm way happier with how it looks now:
Tomorrow I hope to repair the driver's side seat frame and get it all finished up!Last edited by CubbyChowder; 02-15-2016, 10:18 PM.Comment
Glad to see the seats turn out so nice. I'm considering doing the same thing.My Garage
Feedback
Instagram: Stone.HopkinsComment
Very happy to say that the seats are finally complete.
I spent today repairing the broken driver's side bottom seat frame and installing the new covers. I didn't snap any photos of the process, but there were a few parts that I had to bend back and re-weld into place.
This whole seat rebuild was a ton of work but fully worth it. I was learning along the way so it took longer, but if I were to do it again it'd go a lot faster.
I'm excited about the finished results and can't wait to get the interior all clean and buttoned up and take the E30 for a ride. But before I do that, I need to finish the suspension rebuild and 5-speed swap, which will be starting very soon.
Those Seats Turned Out Amazing!Bmw CCA # 490080
1995 525iA RIP
1987 325e Cirrusblau-Metallic/Pacific Blue (Daily)
DSC_1725 by Matthew Johnson, on FlickrComment
Looks like a great project so far man. I love that rack you built, its awesome to see the full process here on r3v as I think I just saw the finished build on IG. Also I just noticed that you live in SLO, thats rad! Ive got a buddy out there right now and I will be moving out to the area shortly myself, maybe we will cross paths.Comment
Thanks a lot man, that's rad you're moving out here soon. Hit me up and come stop by the shop sometime when you do!Looks like a great project so far man. I love that rack you built, its awesome to see the full process here on r3v as I think I just saw the finished build on IG. Also I just noticed that you live in SLO, thats rad! Ive got a buddy out there right now and I will be moving out to the area shortly myself, maybe we will cross paths.Comment
I traded some work for a late model parts car recently:
As you can see, it's already partly disassembled but has everything else I need to finish my 5-speed swap as well as a few other little odds and ends. I'm going to part out what's left when I'm done with it and then take it to the scrapper.
I was pleasantly surprised to find out that it had a new clutch installed recently, so the clutch, pressure plate, flywheel and TO bearing are in fantastic shape, so I'm going to reuse these parts in my E30 and sell my new clutch kit:
Then I got two packages full of goodies from Ireland Engineering!
Their super short shift kit and DSSR:
I cleaned the shift carrier, installed the delrin bushings in the front and prepped the rear carrier mount for a delrin bushing which I still need to order:
IE 22mm/19mm adjustable sway bar kit:
And all new replacement brake parts:
I love getting parts in the mail :DComment
It's a lot of work, I don't think it's overly difficult to do but I guess that depends on your experience. I've never done a 5-speed swap but I've done a ton of research and am gathering all the parts I need and have an idea of what's involved. I'm lucky to have a lift in my shop and a transmission jack, which will really help make this job easier for me. Having a parts car to pull all the little odds and ends off of is a big plus too, I think trying to source each little part individually on the forums would really complicate the whole thing.
If it's something you're considering doing, I'd suggest checking out this thread over on E30tech, it has a lot of good info: http://www.e30tech.com/forum/showthread.php?t=108141Comment
Nice! I know exactly where both are! The spring club from high street was my go to! I miss SLO. I'll definitely let you know if I am ever back down in the area!
1991 LS1 Swapped 318is
Instagram:
https://instagram.com/saltybeast/
LS Build Thread:
https://www.r3vlimited.com/board/for...s-e30-ls1-swapComment
