BBS RS032 (dream come true) =)
  • e30onBBSs
    • Dec 2014
    • 1347
    Originally posted by 15Michaeljoseph
    So what did you use to strip the green?
    Just curious since I have a set of gold factory weaves that were spray painted silver, and I want to see if I can strip only the cheap silver off.
    Sent from my XT1064 using Tapatalk
    Rustoleum aircraft finish remover. Used about a can maybe a tiny bit more for the two faces and the two green waffle caps front back and the threads lug holes etc.
    It works great for spray paint, it is time consuming though to get each nook and cranny covered with a thin layer so it just doesn't drip off. 100% worth it though! If weaves have the same factory paint as these you should be left with a nice factory finish. $13 a can at Walmart + gloves and tooth brushes. I already had gloves, but you will probably need at least 10 gloves. If you get too much stripper on them they start to deteriorate and the stripper gets through to your skin and starts to feel weird (nothing crazy but no bueno). It's really not a lot before they start bubbling, at least for nitrile gloves which I use.
    I got a 6 pack of medium toughness toothbrushes for $1 total at walmart as well. It's worth getting a paint mask thing too if you don't have one. Washing the stripper off the wheels makes it really fumey and I would not be too comfortable cleaning the wheels off without a face mask on unless I was outside with a hose. During the actual brushing I wasn't always wearing mine and I didn't really notice any fumes, but it definitely reacts with HOT water especially. Cold water congeals it, a lukewarm mix is good.
    BMW tech
    Umass Amherst
    05 wrx sti
    • 15Michaeljoseph
      • Aug 2013
      • 1693
      Thanks! I'm going to attempt it when it's warmer.
      (OO=[][]=OO) For Life
      • AWDBOB
        hooptie connoisseur
        • Aug 2013
        • 4452
        After refinishing a set of RS', I can't say that I would ever do it again. Get a tumbler for the bolts, it's the best way to clean em IMO, but without buying new stainless ones, it's extremely difficult to not have them chip/rust unless you have someone coat 'em. Have fun sanding the lips haha. I think I did 800-1200-1500-2000-2200-2500 or something of the sort.
        • e30onBBSs
          • Dec 2014
          • 1347
          Making some progress on the faces, looked up how to prep and some people said 800 but I went with 220 because there were some deposits of something. Going to go self etching primer then tons of thin coats of "brushed metallic" spray paint we have at walmart. Then it's time for the lips to be sanded XD
          BMW tech
          Umass Amherst
          05 wrx sti
          • e30onBBSs
            • Dec 2014
            • 1347
            Did some more sanding in the minor deposits that were left, primed and painted! I'm very pleased with the finish! Getting a spray paint spray gun is definitely a big help. Also cleared the heads and got all paint off the face both sides. 2 coats of etching primer, and 2 of regular primer, and 3 of brushed metallic......
            Still need to do waffles, 3 more faces and lips XD but it's coming along great!
            BMW tech
            Umass Amherst
            05 wrx sti
            • Kershaw
              • 11822
              That's how I polished mine. Makes it pretty easy. I just held 1200 grit wet sandpaper to them. At some point I'll remove the bolts and valves and redo it with 2000 grit, the silicone will keep it glued together. After cleaning my bolts initially and clearing them, the clear just flaked off the bolts and lips. I'm going to go SS bolts and just keep the lips polished.
              AWD > RWD
              • ThatOneEuroE30
                • Dec 2013
                • 8626
                Looking good. I refinished my OZ turbos. I've heard of letting bolts sit in Coca cola over night to clean them up. for my lips I wet sanded them starting at 120 grit all the way up to 3000 grit and then went over them with a buffing wheel and compounds for a nice cut on bare aluminum and then went over it with mothers mag an aluminum polish and they came out really nice. I also used some eastwood BBS silver spray paint and it looks awesome.
                1991 318i 4dr slick top
                Mtech 2 turbo restoration
                • LJ851
                  • 7919
                  Originally posted by e30onBBSs
                  Many coats/ brush strokes later, still have to get factory paint off.. But the shitty green is mosty gone.
                  Wait, you are a girl ?
                  Lorin
                  The M30 is God's engine.
                  • e30onBBSs
                    • Dec 2014
                    • 1347
                    Nope that's a friend haha
                    BMW tech
                    Umass Amherst
                    05 wrx sti
                    • e30onBBSs
                      • Dec 2014
                      • 1347
                      That's pretty boss actually! Might do that for the last grits
                      How did you apply the mag?
                      BMW tech
                      Umass Amherst
                      05 wrx sti
                      • ThatOneEuroE30
                        • Dec 2013
                        • 8626
                        Microfiber cloth. Rub it in until
                        It turns the rag black and then wipe off.
                        • e30onBBSs
                          • Dec 2014
                          • 1347
                          With another microfiber?
                          BMW tech
                          Umass Amherst
                          05 wrx sti
                          • e30onBBSs
                            • Dec 2014
                            • 1347
                            Sanded 3 of the waffles down, finished clearing all of the bolts! Stripped the last face, some of the paint is still stuck. PITA but it's coming along still. Can't wait to see them on the car
                            BMW tech
                            Umass Amherst
                            05 wrx sti
                            • e30onBBSs
                              • Dec 2014
                              • 1347
                              Two of the wheels are complete, the last two are almost done. I can't freakin wait to have these on the car. Just need tires..
                              BMW tech
                              Umass Amherst
                              05 wrx sti
                              • Kershaw
                                • 11822
                                They look great!
                                AWD > RWD
