85 323i grey market euro - M tech 1 build.
  • reelizmpro
    • 9551
    #46
    Well, it seems original used M tech 1 kits have doubled in price while still needing repair work. I refuse to pay $2-3k for a kit that needs work, even if it is original. With that said, I bought the CEP Plastiflex M tech 1 kit. It's a 1:1 copy of the original kit right down to the indentations for the stickers and ribs. The parts do seem thin and are very light but I don't have the originals to compare these to. Besides, if the parts are as strong and flexible as they say they are, they don't need to be as thick or heavy. It will be very hard to tell OE from this kit once finished and painted.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • kronus
      • Apr 2008
      • 13032
      #47
      do the various mounting holes in those come drilled?
      cars beep boop
      • pandaboo911
        • 2070
        #48
        Doesn't look like it. Probably a secondary op they skipped to keep the price down.
        As long as the plastic is flexible they should hold up as well as OE stuff.
        • jaywood
          • Jul 2010
          • 4528
          #49
          I have the CEP kit as well. Please post up pics of mounting. I haven't gotten around to doing mine yet!
          • 2002jm
            • Sep 2005
            • 2073
            #50
            m-tech 1
            You are ahead since you do not need to pay to repair the m-tech 1 kit. Unless you are re-building a 'real' m-tech euro car, I think this is a great way to have a kit and not have the work of repairing. Going to look good!
            jm
            • KIRIEIW
              • Dec 2012
              • 3385
              #51
              Can't wait to see pics of the car with the kit installed, I also refuse to pay $3k for a kit that needs work and paint. The dream would be to put a Mtech 1 kit on my coupe but I don't see it happening anytime soon being the cheap ass I am.
              1992 e34 Touring- S50 Swap
              1992 325i-S50 Swap (SOLD)
              1991
              • Court M3
                • Jan 2004
                • 6713
                #52
                Updates?
                Continuous For Sale Thread
                323i s50
                • reelizmpro
                  • 9551
                  #53
                  At this point, I'm trying to decide what suspension to put on it, wheels (thinking Alpinas) and which bodyshop to drop it off at. It's registered non-op for the year so I am taking my time.
                  88 M3 - LACHSSILBER
                  • 2002jm
                    • Sep 2005
                    • 2073
                    #54
                    euroweaves
                    Might want to look into euroweaves. Something about the m-tech one and euroweaves, that looks really good...of course Alpinas are nice too:)
                    jm
                    • Old city bimmer
                      • Jun 2014
                      • 1114
                      #55
                      Most Mtec look good with some kind of BBS wheels
                      323i MTEC1
                      Z3 coupe
                      E60 M5
                      • reelizmpro
                        • 9551
                        #56
                        I have a set of euroweaves and have considered both euroweaves and BBS but I feel the M tech 1 has more of a classic look. Alpina wheels are very classy. I have BBS style wheels on the M tech 2 vert, Style 5's on other cars, etc. I figure I can swap them back and forth if I prefer Alpinas on the M tech 2 instead. Time for something different but if I come across a deal, who knows what I'll end up with.
                        88 M3 - LACHSSILBER
                        • Old city bimmer
                          • Jun 2014
                          • 1114
                          #57
                          True- Alpina wheels are time classic that never get old.
                          323i MTEC1
                          Z3 coupe
                          E60 M5
                          • reelizmpro
                            • 9551
                            #58
                            Been busy but today I adjusted the timing to try to get this thing to run decently without idling too high. If I lower the idle to around 900, there is no power. If I advance the distributor, the power is there but it idles at 1500RPM. I wonder if the smog shop will take issue with this. Anyone with a 323i in CA have experience smogging one of these?
                            Anyway, although the plasti dipped dash looks a lot better than it did before. I sprung for a used dash since the price was right. At the end of the day, I am sort of a perfectionist/purist and the dash being such a critical part of the interior is no different. So, I will be installing this new crack free dash and probably have this one wrapped.
                            88 M3 - LACHSSILBER
                            • kronus
                              • Apr 2008
                              • 13032
                              #59
                              I've smogged mine. they check the distributor advance with a timing light and it has to match their specs.
                              if yours is timed to the correct mark, it should not be idling weird unless you are having an issue with your aux air slide valve being stuck open. I had that, ended up hiding the end of a finger of a rubber glove under the hose going to it to block it off, passed.
                              cars beep boop
                              • reelizmpro
                                • 9551
                                #60
                                I was reading up on the air slide valve being coolant temp controlled and often failing but there's not a lot of info about the valve. I may be experiencing the same issue as you.
                                88 M3 - LACHSSILBER
