Martine, the wild BMW E30 addicted to crystal meth
  • Gabmartine1000
    • Jan 2016
    • 9
    The main idea behind this build is "quite" simple; I wanna scare the sh*t outta myself everytime that I'll go WOT"
    Martine; she's a cute little 1989 2doors E30. Less than 80 000km on it, all putted in by the first owner which, I'm stuffing a S38B36 out of an 1992 E34 M5.
    Obviously, the +300hp N/A isn't going to be enough for the build..
    Ultimatly, the goal is to achieve +850whp (1000hp) on a mustang dyno. (Do you get where the "meth" in the title comes from now?)
    You can also follow the build on Instagram: @gabnewhouse
    There it is!
    http://www.r3vlimited.com/board/showthread.php?t=382511
    http://s1325.photobucket.com/user/ga...deshow/Martine
  • TimeMachinE30
    • Jun 2014
    • 3749
    Well that is pretty silly.... sub'd
    How come this motor? Other motors not easier, more cost effective?
    ACS S3 Build / Dinan 5 E34
    • Gabmartine1000
      • Jan 2016
      • 9
      Goals for summer 2016
      My goals for summer 2016 are:
      Getting the (all the exterior) widebody, suspension, brakes, 5lugs and cage done.
      I'll be fitting some massive 18x10 ET10 285 & 18x12 ET12 335 on it!
      This is where the car's at right now:
      Not much done to the body yet. Still prototyping
      Interior is temporary in (Look at that crack-free dashboard)
      Engine's in and almost ready for the startup
      • Gabmartine1000
        • Jan 2016
        • 9
        Even if I'm a huge fan of the S54, I scored quite a good deal on the entire thing so, yea. That's pretty much it. I mean, who would spit on a S38 for a boosted build?
        • Griff_
          • Jul 2015
          • 26
          Hell yea! Looking forward to the build this summer; I will be building my race car this summer as well.
          • downforce22
            • Aug 2009
            • 3189
            why did you get rid of the intake manifold? You will need one if you do actually go turbo.
            • kronus
              • Apr 2008
              • 13014
              you, uh, might want a radiator..
              cars beep boop
              • Garage30
                • Aug 2015
                • 123
                Holy power goal batman, I'm sure you can scare yourself with less in an e30!
                Euro car and parts export business based in the Netherlands, specialized in E30 Tourings!
                Instagram: @garage30_ WWW.GARAGE30.NL
                • Gabmartine1000
                  • Jan 2016
                  • 9
                  I'm runing Megasquirt PNP2 which uses a MAP sensor, no more MAP needed
                  I'll also be runing a custom intake manifold since the stock one didn'T wanted to clear the M5 brake booster
                  • Gabmartine1000
                    • Jan 2016
                    • 9
                    Actually, You can see the rad peak trough the front bumper. It's a Griffin alu rad with a slimfan on it
                    • Sh3rpak!ng
                      • Jan 2014
                      • 2667
                      Well shit. This sounds sick. Subbed. Cool to see a new member post such solid content and impressive work in the first 5 posts.
                      Shadetree30
                      • Dagamus(NM)
                        • 590
                        My favorite motor
                        Gun control means using both hands
                        Sex, Drugs, Rock 'n roll. Pick two.
                        • Gabmartine1000
                          • Jan 2016
                          • 9
                          Quick Update:
                          Refreshing/tuning the ITB! MAP sensor shoul be plugged in by the next weekend/ almost ready for the first startup!
                          • kronus
                            • Apr 2008
                            • 13014
                            where did you get those? I need a couple and they are NLA as far as I could tell..
                            cars beep boop
                            • Gabmartine1000
                              • Jan 2016
                              • 9
                              These are OEM from the car, I used carefully a drill with a metal brush + new o-rings. Can't you get them at the dealer if anything?
