Half-Life | '91 DS 318iS Slicktop | Track & Weekend Warrior
  • UNHCLL
    • 8789
    #166
    Pusher fan will be more efficient than a puller at cooling.
    Hood vent looks like a nice design, will be great to see it integrated.
    That Chase Bays radiator design looks terrible.
    Cutting out the bottom of the core support, is just poor engineering.
    Question on your tuning - how aggressive is your ignition map? As you know, your ignition map/advance will have a pretty big impact on engine temp.
    Below the radar...
    • wworm
      • Dec 2016
      • 1719
      #167
      ^I was always under the impression pullers were more efficient?
      1984 Delphin 318i 2 door
      • Digitalwave
        is a poseur
        • 6276
        #168
        Originally posted by mr.
        Mind me asking how you cleaned up the vacuum lines that lead to the (brake booster?) I think it is
        Looking to do the same clean up with mine before I get it back on the road after some head work and general maintenance
        My silicone intake elbow doesn't have the V that splits off to the check valve, but it's not necessary. I just used silicone vacuum tubing to replicate that area with the V split removed. You still need the check valve of course. Make sure it's VACUUM line or it may collapse.
        Thanks, I can't wait to get the vent on there too. My timing is fairly conservative/moderate as far as I know. We did not push it much on the dyno as I was happy with the power as is. I don't have much to compare it to though, most of the Megasquirt maps I've seen are for turbo cars.
        I've been told the same, as pusher fans block flow to the radiator when the car is moving since they are physically in front of a large portion of the fins.
        RISING EDGE
        • mitchlikesbikes
          • Dec 2013
          • 858
          #169
          Excited to see your mounting of the spoiler. I currently have mine mounted but still need to get ahold of some support rods. Are you planning on running 4 support rods?
          IG: @mitchlikesbikes
          • mr.
            • Jun 2013
            • 513
            #170
            Understood, is that a Miller intake elbow or the GE ones that he is no longer producing?
            • Digitalwave
              is a poseur
              • 6276
              #171
              Mine is the GE. I just looked at the Miller one, and I don't understand how it would work. It looks like they placed the ICV port in the wrong spot. It would be on the top or the bottom of the elbow, instead of on the inside curve.
              EDIT: the Miller one is designed for the PSIK which routes the intake tube straight downwards, which is why they made the port that way. This wouldn't work for most traditional intake designs.
              RISING EDGE
              • mr.
                • Jun 2013
                • 513
                #172
                Right right, yeah, the Miller piece was designed for their PSIK system, but after lots of demand they started selling them separately apparently.
                Also don't see how someone could make it work on something other than the Miller kit
                Have asked a couple of people who might be able to find a GE one but no luck so far, bummer.
                • Digitalwave
                  is a poseur
                  • 6276
                  #173
                  Dropping in some updates. Simon graciously picked my car for the May COTM!
                  Here are the pictures I shot for COTM:
                  With the "street/tuning" dash:
                  With the more simple "race" dash:
                  Got to be on the track last week for some fun sessions. Prior to that I was able to get some projects on the car, but not finished per se. First up, I got my Kooglewerks splitter and spoiler mounted and the supports installed. I also installed the N15 Designs E36 side vents on the hood. The center vent got delayed in production, but should be here this week. I wanted *some* venting before the track day, and I guess now I'll be able to compare just the side vents to the sides + the center vent as well.
                  Measured 5x, drilled once:
                  Cutting the hood was surprisingly easy. I just used a Dremel with reinforced discs. The cuts came out well. The E36 vents fit the contour of the E30 hood pretty spot on.
                  The Kooglewerks front splitter, though not that large, is SOOOOO much stronger than those flimsy ABS plastic ones. It was quite solid, even before installing the braces. I think the "depth" of it helps a lot in resisting any bending or flexing.
                  Before the track day, I flushed the brake fluid (AP PRF), did a bolt check, and removed the rear spring pads to lower the back 1/4-3/8". I'd say the new changes helped, as I lowered my personal best at PBIR by almost a second (down to 1:34.15). The next thing I am going to try is setting the rear sway bar on the "soft" setting, as it is currently on "stiff." The car is over-steer prone, especially on corner entry. I believe I will be faster if I can make the car a little more pushy, so I can confidently drive it harder.
                  Once the center hood vent arrives this week, I will bringing all of the aluminum parts (splitter, spoiler, all 3 hood vents) in to get powdercoated satin black.
                  I finally started poking around and planning my surge tank setup. I'm sick of having to run with a full tank on the track, and don't want to risk a hole in a piston with fuel starvation. After reading the SCCA and NASA rule books, I think I have a good game plan. I will post more on that soon as I start installing parts. Here, I was poking around the area to see where some good spots are to run fuel lines and bulkhead fittings into the trunk.
                  Really love all of my Condor bushings on the car. I've never driven an E30 with such a direct, tight feel, especially in the rear suspension.
                  Small detail, but I ran a longer vacuum line to my MAP sensor, so I could tuck it away under the wiring bulkhead and by the brake booster. It was previously ran up by the strut bar, since the hose I had on there was just a little bit too short. Now, you probably wouldn't notice it if you didn't know what to look for.
                  RISING EDGE
                  • wworm
                    • Dec 2016
                    • 1719
                    #174
                    keeps getting better! Kind of surprised I hadn't heard of the e39 bumper seal thing yet. Seems like a nice little touch there.
                    vents and aero bits look damn good. No plan to paint them?
                    • parkerbink
                      • Jun 2004
                      • 10134
                      #175
                      Congrats on COTM & the car looks amazing!
                      • Digitalwave
                        is a poseur
                        • 6276
                        #176
                        I heard the E39 seal mentioned in a thread. All the aluminum stuff is going to get powder coated. I’m just waiting for the center vent to arrive so I can do it all at once. Plus, it was good to drill and mount everything first so I don’t scratch them later on.
                        RISING EDGE
                        • wworm
                          • Dec 2016
                          • 1719
                          #177
                          I heard the E39 seal mentioned in a thread when I was researching the EVO SEAL for plastic bumpers (it works but it’s a bit short). The E39 is much cheaper, and is very long. Easy to trim to length. All the aluminum stuff is going to get powder coated. I’m just waiting for the center vent to arrive so I can do it all at once. Plus, it was good to drill and mount everything first so I don’t scratch them later on.
                          right on! I like the raw aluminum but it'll definitely make the car look way more "finished" if everything gets painted. Definitely a solid call to assemble pre paint. Its been really cool to see this car progress. Very stoked to see more.
                          • Joeyz31
                            • 178
                            #178
                            Awesome man! The Hood & kooglewerks bits turned out great!
                            This continues to be one of my favorite E30s out there.
                            • Digitalwave
                              is a poseur
                              • 6276
                              #179
                              Thanks for the kind words guys!
                              RISING EDGE
                              • econti
                                • May 2014
                                • 1083
                                #180
                                I'll be honest I was concerned about the bonnet vents looking trash but man they turned out very well.
                                A well deserved COTM for you
