*!Build of the year candidate!* Strange PNW Build: E30+Volvo
  • adam.nonis
    • Apr 2017
    • 755
    #256
    Quick valve adjustment
    Suppose these are factory installed oil quart rings? Floating around the valvetrain
    • Mwishlist
      • Jul 2013
      • 505
      #257
      Man, this is a fantastic build! Nice job.
      Thank god, R3V was getting boring since the ginger kid wrecked his car. - Stonea
      • adam.nonis
        • Apr 2017
        • 755
        #258
        I wonder if that’s why it wasn’t getting warm?
        • adam.nonis
          • Apr 2017
          • 755
          #259
          Cousins?
          • adam.nonis
            • Apr 2017
            • 755
            #260
            Starting the custom hood hinge process.
            • Frog
              • Jun 2010
              • 980
              #261
              Subscribed. This is insane. I just want to learn to use my stick welder and I can't even figure that out.
              Winner winner chicken dinner?
              My Seller Feedback Thread
              • cheffy30
                • Sep 2016
                • 1159
                #262
                missed you last tuesday.
                lookin sooo good...
                '90 325i sedan daily driven
                '85 325e coupe also a daily
                • adam.nonis
                  • Apr 2017
                  • 755
                  #263
                  lookin sooo good...
                  4 out of 6 spark plug ends pulled off when I was taking the plugs out to do the valve adjustment. We tried to clean and recrimp them, but it was running on three cylinders. Ordered a new ignition lead set and it’s all better.
                  • LateFan
                    • May 2013
                    • 4436
                    #264
                    Hey, I was looking back at the first page.....which Volvo engine is that that you had in there? It's 4 cyl but twin cam - I don't know that one.
                    • adam.nonis
                      • Apr 2017
                      • 755
                      #265
                      It was a Volvo Penta AQ171. It’s for marine applications, comes with a forged crank with longer stroke to make it a 2.5l. It uses the standard single overhead cam B230 (2.3l) block and puts the B234 dual overhead cam head on it.
                      • adam.nonis
                        • Apr 2017
                        • 755
                        #266
                        There was a regular 16 valve 4 cylinder that Volvo used in the 740, 940 and 960. It had a different block configuration with balance shafts and stuff.
                        • LateFan
                          • May 2013
                          • 4436
                          #267
                          Ah, thanks.
                          Would either of those make a good / fairly simple swap into a 122? Better choices than a built-up B20 for a fun daily wagon? The ones you see with a 5 cyl white block sound like a major project.
                          • adam.nonis
                            • Apr 2017
                            • 755
                            #268
                            Ah, thanks.
                            Yeah, but you need to swap a fair amount since you'd be converting to EFI at that point. Someone makes mounts to swap them in. Even the single overhead cam 4 cylinder can make plenty of power.
                            Yeah, converting a whiteblock to RWD is a decent endeavor. Put it this way, I decided to swap the entire chassis instead. LOL More fun might be putting carbs on a DOHC redblock instead of converting to EFI.
                            • flyboyx
                              • 8371
                              #269
                              ah.....so the reason you are going to all this trouble is because the vulva was originally front wheel drive? i was wondering what your reasoning was.
                              Gigitty Gigitty!!!!
                              • LateFan
                                • May 2013
                                • 4436
                                #270
                                Nope (unless you’re just pulling his chain). A whiteblock 5 cyl is a transverse car - fwd & awd. A 122 is a classic rwd. They rallied them back in the day.
