*!Build of the year candidate!* Strange PNW Build: E30+Volvo
  • adam.nonis
    • Apr 2017
    • 755
    #226
    Well, that wasn’t the weather issue I expected to have. It was just too windy to get anything done. I had to take the “workshop” down so it wouldn’t blow away or tear. All I could get done was get the driver’s side put back together. I’m leaving the fender unbolted for now cause I’ll need to pull them to finish the cowl sheet metal.
    • vtechnik
      • Jan 2018
      • 379
      #227
      So bizarre yet so cool. I used to have an amazon and something like this is just boggling to me. Well done.
      1988 ~ Lacey ~ 325iS
      • 2mAn
        Señior Mod
        • 21053
        #228
        This is coming together so nicely!
        That sucks about the garage thing, it really is a must in the PNW
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        Make R3V Great Again -2020
        • adam.nonis
          • Apr 2017
          • 755
          #229
          Just get something done every day and it’ll eventually be finished.
          • flyboyx
            • 8371
            #230
            How do you eat an elephant? Start at the ass, and take one bite at a time.....
            Gigitty Gigitty!!!!
            • adam.nonis
              • Apr 2017
              • 755
              #231
              Welding and grinding in the dark. Hahahaaa...
              It’s more “flat panel” than I wanted, but I need clearance for the bracing on the hood, I need pockets for hinges (or latches), and I just wanted it done. Hopefully this weekend the front sheet metal (besides the hood) can go on for the last time.
              Another question. What is the interior panel that goes under the steering column called? I need to find one, but searches on eBay aren’t turning up much.
              • delamaize
                • Nov 2013
                • 1465
                #232
                Kick Panel, IIRC
                here are 3 I found:
                https://www.ebay.com/itm/BMW-E30-OEM...AAAOSwObhaXSRN
                https://www.ebay.com/itm/OEM-BMW-E30...UAAOSwG0tZrDtF
                This one is for Airbag models.
                https://www.ebay.com/itm/BMW-E30-3-s...gAAOSwBUVZyeND
                Dumpster Fire Pilot
                • Staszek
                  • 2533
                  #233
                  Subscribing to this, just read through it all, wow, you have skills!
                  • cheffy30
                    • Sep 2016
                    • 1159
                    #234
                    can't wait for a ride...
                    '90 325i sedan daily driven
                    '85 325e coupe also a daily
                    • LateFan
                      • May 2013
                      • 4436
                      #235
                      I also decided to cut new grille plates. Just finished deburring them. Need to bend the tops and paint them black. I wanted something just a bit different than stock.
                      Curious how you made these. Is that a thick alum sheet and then a CNC machine cut it out? How does it make a sharp inside corner?
                      Thanks -
                      • adam.nonis
                        • Apr 2017
                        • 755
                        #236
                        Thanks -
                        Yeah, it's .125" aluminum. It's not sharp in the corners. 6mm cutter, so 3mm rad corners.
                        • adam.nonis
                          • Apr 2017
                          • 755
                          #237
                          Should feel a lot like an E30. Lulz. Just look a hair different.
                          Only got about four hours in today. Also only got about halfway to where I wanted to be today before the sun went away and it got coooold. Story of my life it seems these days.
                          I just want to be able to put the front clip back on tomorrow. We’ll see.
                          • adam.nonis
                            • Apr 2017
                            • 755
                            #238
                            Easy bake oven
                            That’s as far as I got this weekend. Gonna try to finish up the front lighting after work this week and give it a bath since the major fabrication is almost done.
                            • 2mAn
                              Señior Mod
                              • 21053
                              #239
                              so cool, I cant wait until its put together
                              Simon
                              Current Cars:
                              -1966 Blue Boat
                              -1969 Red VW
                              -1986 White BMW
                              -2006 Green Thing
                              • nauqneyugn
                                • Oct 2012
                                • 201
                                #240
                                Do you live near Ingram? If so, my dog and I walk by your XC most days.
