Can we walk through oil pan stuff together? Trying to look at the discrepancies from RN to RNC engines.
So, RNC oil path (as I understand it):
Pickup into pump:
Out of pump into oil cooler:
Cooler inlet and outlet:
Then to oil filter on the side of the block:
RN (in this case B6304):
Pickup into pump:
Out of pump into filter:
Out of filter into block:
(Note that this port exists in the RNC block, but is blocked off by the pan):
So, if I want to use the rear sump pan, do I just need to black off the oil filter in/out on the side of the block and just use the bottom mount filter?
Thoughts?
Pickup into pump:
Pickup into pump:
Thoughts?
