*!Build of the year candidate!* Strange PNW Build: E30+Volvo
  • ForcedFirebird
    • Feb 2007
    • 8300
    #616
    Originally posted by adam.nonis
    An older version of this machine is what I use. Simple, but most of the stuff I make is pretty simple too.
    3 axis KL-6090 Desktop CNC Router (24 x 36 x 6 inch), Mach3 Ethernet Connection https://www.amazon.com/dp/B00I8R6ZWE..._ZQ0.BbD6ZJXB1
    My definition of "older" is quite different lol.
    1981 Kitamura MyCenter2 3 axis...
    It has 19bk of bubble memory with 3 line drip feed (or punch tape, which was removed).
    Runs on pure g-code, but if you are crafty, you can put in can cycles to save space.
    john@m20guru.com
    Links:
    • adam.nonis
      • Apr 2017
      • 755
      #617
      Been a while since I posted anything. Just working on dumb detail stuff. Alternator mount.
      Made a floor mount shifter since I’m switching to an early trans and don’t want to use the sheet metal shifter carriage
      Remains to be seen how well it works.
      Throttle body adapter to shift the angle and to use a Volvo 960 cable 65mm throttle body
      Grabbed a backup bellhousing so I can make a backup trans if needed.
      Machines some caliper piston masking plugs for a set of Volvo R calipers I’m throwing custom paint at
      Made a custom bed side table for my wife for Christmas.
      Not pictured
      -got an OEM S40 engine harness to mod
      -got all the clutch bits final assembled
      -got the trans attached for last time
      -made FPR mount
      -made IACV mount
      -started fabricating heater hose hard lines
      • IRON-E
        • 16548
        #618
        You had me going through withdrawals, thinking you went MIA on us.
        @IRON-E30 aka Edwin:D
        • adam.nonis
          • Apr 2017
          • 755
          #619
          Nah, just most of it is boooooooring.
          • parkerbink
            • Jun 2004
            • 10138
            #620
            Wow! As usual amazing work!
            • jeenyus
              • Aug 2011
              • 2064
              #621
              "made some custom stuff, made it looks really nice, put together an entire car out of CNC'd parts, swapped in a 5cylinder Volvo engine into my Miata... OH, i also made my wife a custom end table in the spare 15 min I had and it turned out nicer than your whole house." -typical post in this thread
              Great work mate. How did you get the bed table to bend like that? Steam?
              • adam.nonis
                • Apr 2017
                • 755
                #622
                [emoji38] sorry, I just assumed people would be more excited to see it when it’s all done and making choo choo noises, and less interested in putting an alternator on the engine still sitting on the roller cart.
                I made it out of a sheet of plywood and I used the router to CNC the end pieces (staggered two different lengths), then cut straights and glued/nailed them making a big stack. Epoxy coated the top. You can see the stitched seam with the two different length end pieces here.
                • jeenyus
                  • Aug 2011
                  • 2064
                  #623
                  I think we all enjoy the putting together maybe more than the actual vroom vroom. That table is great and I'm sure your wife loved it.
                  Sent from my Pixel 2 using Tapatalk
                  • adam.nonis
                    • Apr 2017
                    • 755
                    #624
                    Heater tubes and a glamour shot
                    • LateFan
                      • May 2013
                      • 4436
                      #625
                      Oh! She's got hardly anything on...oh my!
                      Just a minute ago I was looking up X-Ray Auto on 46th...Olde Ballarde yah sure!
                      • adam.nonis
                        • Apr 2017
                        • 755
                        #626
                        Here’s a project car for ya
                        • the_eskimo_wonder
                          • Sep 2017
                          • 182
                          #627
                          Well, I’ve got a 215mm recess in the Volvo dual mass flywheel. I have three options, A) buy a larger E30 disk made for dual mass and have it trimmed (losing some friction material $120), B) buy an E21 sprung center 215mm disk and drop it in (sub $100) or C) pay to have an unsprung BMW center put in a Volvo disk by one of the various performance clutch places (+/- $200 for stock sized organic friction disk). I know $80-$100 doesn’t seem like a ton, but I’m on an uber tight budget. I do pretty much everything out of scraps or used parts.
                          I know I'm late to the party but I've got a brand new Luk unsprung 228mm clutch disk that's been collecting dust forever. If you want to try the shaved down 228 approach, I'll happily send it to you.
                          Build Thread
                          • gath
                            • 577
                            #628
                            Very impressive and inspiring work :)
                            • adam.nonis
                              • Apr 2017
                              • 755
                              #629
                              I appreciate it, but this wound up being a blunder on my part. I actually needed an unsprung 240mm disk. It’s silly, but I forgot to check if closed was zero on my calipers after a co-worker used them. They weren’t. I would up finding a Sachs clutch kit for a 90 535 on Amazon for cheap that had what I needed. I only used the disk and now have a new pressure plate that I’ll never use.
                              • rzerob
                                • Jun 2013
                                • 2315
                                #630
                                I always love when this thread gets updated. And it looks like it is nearly done. So, will this be running by the end of the month? If not what is the plan/eta?
