*!Build of the year candidate!* Strange PNW Build: E30+Volvo
  • adam.nonis
    • Apr 2017
    • 755
    #886
    Another day of block sanding. Wheeeeee...
    This is what guide coat does for those of you who don’t normally do bodywork. It allows you to see sand scratches and low spots
    Then you keep blocking until the black is gone
    Always wear your respirator when sanding
    Reprimed the roof, second embossed fender, both modified door jambs and the hood
    Cut the first part of the new hood hinge V1
    Oh, and Brown Bear got me. Ugh
    • oekundar
      • Sep 2007
      • 964
      #887
      Ugh!!! Can’t catch a break with the vehicles! Fabrication work looks great!
      BMWCCA #389756
      • adam.nonis
        • Apr 2017
        • 755
        #888
        I keep thinking “I feel like I’ve been here before”
        • lukeADE335i
          • Apr 2013
          • 1389
          #889
          Your progress is always an inspiration Adam! Like your de ja vu shot there - when you have kids, they grow up so quickly!
          Bad luck on your daily also being hit - I think people are just too distracted / don't look properly when driving these days.
          On my drive to work, I see so many cars with damage.
          My e30: OEM+ with M30B35
          • adam.nonis
            • Apr 2017
            • 755
            #890
            Not a lot photo’ed today. I just needed a “reset” day. Had Easter morning with the kids. Cleaned the shop. Mopped. Got the hatch cut in. Pulled the grille shell. Started bodyworking the car side door jamb on the passenger side. Made dinner. Finally sitting down with a beer. Probably be asleep in about twen.............zzzzzz
            • luckybk
              • Jan 2019
              • 127
              #891
              Those fender curves are going to look amazing in AW when you get the clear coat on there. You aiming for the picnic this summer?
              • adam.nonis
                • Apr 2017
                • 755
                #892
                I won’t be at the picnic this year. I’ve got a different event on the same day that a good friend of mine puts on. He really shoulda checked with me before he scheduled the date.
                • adam.nonis
                  • Apr 2017
                  • 755
                  #893
                  Also, it’s Chamonix White.
                  • adam.nonis
                    • Apr 2017
                    • 755
                    #894
                    This morning/evening I got the door, fender and door jamb all cut in on the passenger side. I also got the driver’s fender and door off the car and re-installed the lower hatch. I blasted and powder coated some hardware and found out that my upper hatch latch is bad. So is the extra one I got. Working on the fix. Also replacing all the hardware with stainless. I know that’s a dump of info, but it’s late, I just got home and I want to get a few hours of sleep in before I start all over again.
                    • adam.nonis
                      • Apr 2017
                      • 755
                      #895
                      Fixed the hatch latch. Made a new piece from Delrin. Also put the passenger door and fender back on and sourced some more stainless hardware
                      A little tip for something I do. Align all the parts before hand. With the seals out. Then drill some 1/8 holes between multiple layers. Be conscious of where you put the holes if they’ll be exposed. Then, when you reassemble you can use pick tools, un-popped pop rivers or 1/8” drill rod to align the panels when you re-install.
                      Once the bolts are tight, pull out the pins and put a dab of silicone/urethane in and over the holes
                      • adam.nonis
                        • Apr 2017
                        • 755
                        #896
                        I’ll try to post more pics later tonight, but I’m reassembling some parts and finally get to see the color in the sun. I love it. It’s hard to photo, but it gets a bit brighter when the sun hits it and a bit warmer in the shade. Bead blasted all the latch components, lubed them up and replaced all the hardware with stainless
                        • LJ851
                          • 7919
                          #897
                          I’ve had two chamonix 2002’s , it’s a beautiful color particularly on 50’s to 70’s machines. Looks great on your Volvo.
                          Lorin
                          The M30 is God's engine.
                          • adam.nonis
                            • Apr 2017
                            • 755
                            #898
                            What was interesting to me was that the paint supplier didn’t have a mix recipe for base/clear. Only single stage. They had to call the PPG library and get the recipe. So my cab has just a PPG code number, not 085 on it.
                            • rzerob
                              • Jun 2013
                              • 2315
                              #899
                              Chamonix is one of those colors that you don't realize how dirty your car is until you clean it.
                              • adam.nonis
                                • Apr 2017
                                • 755
                                #900
                                Perfect for a wet PNW driven car!
