Project Weißer Regen: 91 318iS Restomod
  • TeXJ
    • 1914
    #586
    ^agree
    1990 325is
    m52b28
    3.73lsd
    g260 (1987 325is 5spd tranny)
    • didithepest
      • May 2017
      • 45
      #587
      third
      • Sophia69IS
        • Nov 2012
        • 12
        #588
        This thread has cost my company some time. Thanks for making this!
        • Jordan
          • 12916
          #589
          Pukar Designs is finished with all of my reproduction stickers and sending them this way, can't wait to receive them! He was able to reproduce a bunch I specifically wanted that he did not otherwise offer without an issue. Highly recommend him!
          https://mtechniqueabs.com/
          • mbonder
            • 2255
            #590
            That is awesome, I've always wanted to replace all of the stickers with new factory-looking ones.
            • Melon
              • Mar 2018
              • 1311
              #591
              Yeah, he's a great guy. We went back and forth several times to get the exact items I wanted.
              5/7.
              Sent from my Pixel 2 using Tapatalk
              I do things.
              • The Reverend Bluejeans
                • Jan 2019
                • 3
                #592
                As you've not built the engine yet, I'd recommend that you use the 1993-5 E36 318iS or 318Ti front timing case. After quite a few idler gear failures on the earlier engine, BMW replaced the idler gear with a curved guide rail in 9/93. The idler gear itself can shit it's bearings but also, the lug that the gear bolts into can break away from the casing. I've seen both. You'll pay buttons for a used later E36 timing case - the chain and gears are the same.
                The part number is 11141739699 and it looks like BMW used it to supersede the older type like yours.
                An M44 one won't do as they have no mounting lug for the TDC sensor.
                  • Jan 2019
                  • 3
                  #593
                  Here's a knackered gear, and a pic of a 318Ti front end.
                  • freeride53
                    • 11972
                    #594
                    Wow! I need a lot of those for my own car (particularly for the driver door jamb), ahead of the body & paint work it'll be receiving this spring. My car was also produced in 6/1990. Given you worked with him to produce these as a one-off, would it be OK to print another batch of some of those stickers?
                    1983 Peugeot 505 STI
                    1992 Volvo 240 Wagon
                    • Jordan
                      • 12916
                      #595
                      I am well aware of the idler gear issue that the early M42's have but realistically the likelihood of it occurring is minuscule at best and I would much rather keep the original timing case casting for originality sake.
                      Pukar Designs owns the property rights for all of the stickers, they can create or recreate any you like. Just reach out to them on Facebook and let him know I sent ya.
                      The doors and front valance got paint on the inner sides today, man do they look scrumptious! Imperiale Collision tells me the exterior of the car should get paint next week! I can't wait!
                      • burkey001
                        • Feb 2011
                        • 608
                        #596
                        awesome
                        88 325is. S54, CSL airbox, Motec M800, Motec C127, Motec PDM15, Stoptech STR, MCS 2 way coilovers, Forgeline wheels, Recaro SPA, Eisenmann, Personal, lots of custom.
                        90 318is. As new OEM+, BBS LM, AST 4210 2 way coilovers, Wilwood SL6R/SL4R, Dynaudio, Recaro Experts
                        • zaq123
                          • Jul 2016
                          • 1538
                          #597
                          What the proper way to paint these things? Doors, hood etc separate first, bolt them and then spray over bolts etc?
                          I’m going to repaint mine come spring and don’t know if I should have them paint the door jamb and back of fenders, install/align doors, hood, trunk etc before the paint and that paint the whole thing. Thank you
                          • Jordan
                            • 12916
                            #598
                            Properly after original would be the paint the doors, hood and trunk off the car, back side / jam out first then a careful backmasking to paint the exterior sides. Once done rehang carefully on the vehicle.
                            You can then mask and paint the mounting hardware if you like. In my case I have all new or replated hardware and I am going to simply run them exposed.
                            In the fender jams it is proper to paint over the hardware. Same with the bolts that fasten the fenders to the valance.
                            I also went has Imperiale go into extra detail recreating the seam sealer beads where the fenders meet the cowl, and where the squared off tip of the fenders meet the nose panel at the front as it was originally.
                            Nose panel without any seam sealer
                            With seam sealer smeared in the gap to minimize its appearance.
                            • zaq123
                              • Jul 2016
                              • 1538
                              #599
                              I also noticed that OEM used some sort of tape on the joint where the fender meets the cowl (horizontal joint, inner part of the fender) and them painted over it. Do you know what tape can reproduce that OEM tape?
                                • Jan 2019
                                • 3
                                #600
                                OK. I'll butt out from now on.
