Zephyr's Lachs M52B30 Stroker Build **ITBs**
  • Metallated
    • Dec 2016
    • 1074
    #31
    Got the engine bolted up but with the head on and the iron block l6 my shitty engine stand bent...
    Ended up moving it onto a cart made by Adam.Nonnis which worked great to wheel the engine out to the car:
    • Metallated
      • Dec 2016
      • 1074
      #32
      Replaced a couple parts on the transmission,
      And finally got the engine in the car!!
      Very happy it's finally coming together, just need to bolt everything together, goal is to have it up and running in a couple weeks.
      • TFJR
        • Feb 2012
        • 561
        #33
        Awesome progress! It was nice we got a day of uninterrupted sun yesterday. You'll have to take me for a spin once shes up and running. Congrats
        1988 325 Lachs Sedan SOLD
        1989 325i Bronzit Beige 2 Door
        SOLD
        2018 Volkswagen Alltrack SE DSG
        Past:1988 325iS Lachs 5 Speed
        • AWDBOB
          hooptie connoisseur
          • Aug 2013
          • 4501
          #34
          Great progress- I'm excited to see this thing buttoned up!
          • Metallated
            • Dec 2016
            • 1074
            #35
            Thanks guys!
            Currently trying to get the motor mounts properly aligned. I'm searching for a manual transmission crossmember and a 328i clutch slave cylinder.
            • Metallated
              • Dec 2016
              • 1074
              #36
              Got the driveshaft sorted with the e30 csb this weekend. Next steps are bolting on all the accessories and installing the harness.
              • Metallated
                • Dec 2016
                • 1074
                #37
                Spent pretty much the entire last 2 days working on the car.. hoping to get it running real soon.
                Grabbed a cleaner hood from my parts car, and I also got some ronal ls's to replace the euro weaves a while ago:
                Also figured out my shift linkage, got a shorter throw with the 328 shifter. The joint was super worn and grooved, but I sanded it down pretty good, up to 2000 grit, and it rotates much smoother. Before:
                After:
                I really didn't feel like loosening the trans and engine mounts to get the b*tch pin in, so instead I just bolted the arm to the transmission... I think it will work perfectly fine and I'm honestly not sure why they didn;t do this from the factory, maybe I'm missing something.
                Whoever owned the car before me had a 1JZ in it, which actually got stolen and the motor ripped out of it, with a lot of stuff being ripped and destroyed in the process, so I installed some not mangled heater core pipes:
                • NufnSus
                  • Apr 2012
                  • 119
                  #38
                  The essence of a DIY swap in one picture
                  Sent from my Moto G (5) Plus using Tapatalk
                  • adam.nonis
                    • Apr 2017
                    • 755
                    #39
                    • Metallated
                      • Dec 2016
                      • 1074
                      #40
                      Looks great, thank you for helping me sort out the obd2 ccv system, I'm jealous of your fab skills.
                      Big thanks to Habla as well for helping me source the last bits for my m50 manifold conversion.
                      • spiDmang
                        • 3941
                        #41
                        Nice work, Zephyr!
                        91' 318iS - S54/6MT Swapped
                        08' E90 M3 6MT - Daily
                        Originally posted by IronJoe
                        Originally posted by 2mAn
                        • Metallated
                          • Dec 2016
                          • 1074
                          #42
                          Originally posted by spiDmang
                          Nice work, Zephyr!
                          Thanks man.
                          Definitely wouldn't have gotten this far without all your help and parts ;)
                          • Metallated
                            • Dec 2016
                            • 1074
                            #43
                            Getting really close now
                            Got the front end together so the car is looking cleaner.
                            Sorted out the cooling system, and started trying to organize the wiring:
                            Also blacked out the interior with the help of Alpha Team
                            Before:
                            After (yes the seat is backwards):
                            • wworm
                              • Dec 2016
                              • 1719
                              #44
                              Any particular reason you're running the OEM CCV rather than an aftermarket catch can?
                              1984 Delphin 318i 2 door
                              • TFJR
                                • Feb 2012
                                • 561
                                #45
                                Did you paint your interior or just swap parts from the S52 Calypso car?
                                SOLD
