S14b23 Drivetrain overhaul and concours restoration.
  • TimeMachinE30
    • Jun 2014
    • 3749
    #31
    So you are getting eaually incredible body work from this? There will be a thread on that too?
    ACS S3 Build / Dinan 5 E34
    • Jordan
      • 12916
      #32
      My car build thread is long standing:
      https://mtechniqueabs.com/
      • AndrewBird
        The Mad Scientist
        • 11898
        #33
        What is your process for cleaning pistons? I need to clean some and wasn't looking forward to all the scrubbing.
        • Jordan
          • 12916
          #34
          They were cleared of the major grime in a parts washing tank at the shop, then bead blasted to remove the baked on crud, then vapor honed to restore the smooth surface sheen.
          • UNHCLL
            • 8790
            #35
            Exhaust valves are trash, throw them away and buy new.
            Penny wise, pound foolish to try and save them. You're installed heights will be all sorts of messed up by the time you re-cut the valve seats and then those valves.
            With new, you can set installed height correctly, once the seats have been re-machined.
            Below the radar...
            • LJ851
              • 7919
              #36
              Originally posted by unhcll
              exhaust valves are trash, throw them away and buy new.
              +1
              Lorin
              The M30 is God's engine.
              • Jordan
                • 12916
                #37
                While I certainly don't disagree my responsibility to this point is disassembly and cleaning. I fully intend to let my machinist determine what is usable with recon and what needs to be replaced. Valves are about $25 each, no big deal if needed.
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  #38
                  Did you bead blast the ring glands as well? I was under the impression that was a no-no.
                  • Jordan
                    • 12916
                    #39
                    I've not had an issue with it in the past, especially followed up with vapor honing. I wouldn't run a just bead blasted piston though, even super fine media leaves them rough feeling.
                    I'm also not really expecting I'm going to be able to use the original pistons, its likely the block is going to need more love than they can allow. Again yet to be seen. The entire bottom end is at the machine shop now and I'm awaiting work on the suck I'll have to deal with.
                    • Melon
                      • Mar 2018
                      • 1311
                      #40
                      I read up on it after you mentioned it in your other build thread, it's an interesting and very non invasive procedure.
                      What's the plan if the block needs to be replaced?
                      I do things.
                      • Jordan
                        • 12916
                        #41
                        The block will be fine, but I'm pretty sure it is going to need more than a dusting with a bore hone... which means in all eventually new pistons. Again we'll let the machinist say whats what. The client prefers to reuse original parts wherever possible, and so does my wallet, but if the pistons need to be replaced it is what it is.
                        • kid325e
                          • Sep 2007
                          • 6422
                          #42
                          Awesome work! Hope you guys are doing good down there. This is Kyle's friend, Paolo. We took a couple classes together in Texas. Do you still have the F10 or did you get another one?!
                          clutchCTRL!
                          Move with a purpose.
                          - 1991 325iX 4dr/5spd
                          - 2000 323i AT
                          2016 Mazda CX3 Sport AWD
                          • Jordan
                            • 12916
                            #43
                            Oh hey Pablo, yeah right after we met at the Gaylord convention center and I got back home some fuckwad kid with no license playing on his phone ran a redlight and tboned my F10 535i. It was a total loss. Multiple airbag deployment, left front hit hard, frame rail shifted, subframe and engine mounts broken. Left rear door and quarter hit too.
                            That's alriiiight though as I upgraded to a M5 instead. Tuned to 780hp/730tq daily driver mode :-) I had to replace 2 barrels and 1 face but was able to salvage my custom wheels.
                            • Melon
                              • Mar 2018
                              • 1311
                              #44
                              Got to love the Texas car scene. Lots of big horsepower vehicles over there.
                              How much would new pistons be, out of curiosity?
                              I do things.
                              • ForcedFirebird
                                • Feb 2007
                                • 8300
                                #45
                                The valves can be tipped to correct height, provided there is enough margin. Hard to tell how deep the pits are in the pics, specially contrasting with the polished surfaces. More so, the seats would be a bigger concern (on a performance stand point) since the further they go into the throat, the worse low lift flow will get.
                                I have seen some real crap valve jobs come out of local machine shops that just care about the engines running, hence the reason I purchased a valve machine and moved the work in-house. Nothing worse than getting some nice flow numbers on the bench, just to have it ruined by a yocal.
                                john@m20guru.com
                                Links:
