S14b23 Drivetrain overhaul and concours restoration.
  • ArtFoodBMW
    • Feb 2014
    • 765
    This is the level of cleanliness I hope to achieve someday.
    • e30sh
      • Apr 2015
      • 618
      Beautiful work. What process did you use to clean your valves?
      • Julien
        • 7471
        wow
        Build Threads:
        • dasmanschaft012
          • Apr 2014
          • 642
          ugh i wish someone would pay me to do this... great work
          We're in deep now boys
          1988 325i SETA - Daily driver
          1988 340iL - Track car
          My M60 V8 swap thread here
          [oo==OO==oo]
          • delamaize
            • Nov 2013
            • 1463
            Oh man, this is getting good...
            Dumpster Fire Pilot
            • TimeMachinE30
              • Jun 2014
              • 3749
              Oh my garsh.
              ACS S3 Build / Dinan 5 E34
              • mike.bmw
                • Dec 2015
                • 1770
                Love this thread. Love.
                • Jordan
                  • 12916
                  Originally posted by kronus
                  Is your throttle body linkage (the dogbone piece) sloppy? any solution in mind? I am struggling to find a replacement one for a set of E28 ITBs I'm sitting on. Moosehead used to make a replacement with bearings, but they're out of production.
                  Linkage on this car is still nice and tight, no slop or axial play. Car only had 40k on it before it was left neglected for 12+ years in a barn.
                  I ultrasonically clean them to start with, then chuck each one of them in a hand drill. I use varied grits of sand paper followed up with WD40'd scotchbrite to achieve the final finish.
                  I do so enjoy this sort of work, being able to do it in trade towards the extensive body and paint work my own car needs is fantastic. Make no mistakes about it rebuilding a S14 is not cheap, and there will be hundred of labor hours involved in this through the final product. I'm at just over 40 hours to this point.
                  Not much to report as I'm waiting on parts, and more time with the vapor honer. Engine/rotating assembly is at the machine shop.
                  New brushes for the starter motor came in tonight so I dropped those on. Still waiting on the new bronze bush set to be able to finish assembling it.
                  https://mtechniqueabs.com/
                  • ttrousdell
                    • Nov 2009
                    • 1770
                    keep up the good work. love detailed threads like this.
                    The Build:
                    • TeXJ
                      • 1914
                      great progress!
                      1990 325is
                      m52b28
                      3.73lsd
                      g260 (1987 325is 5spd tranny)
                      • Court M3
                        • Jan 2004
                        • 6713
                        Attention to detail as always in your builds.
                        Continuous For Sale Thread
                        323i s50
                        • Jordan
                          • 12916
                          A few things today. First off the engine harness came to him missing some connectors, why someone would lop them off is beyond me but yet here we are.
                          A few minutes looking at wiring diagrams and confirming with my Fluke showed me these were the AFM and Barometic pressure sensor connectors. If anyone has a junk old 325e or 318i harness they can cut these off of for me that would be fantastic. Need them cut back into the harness as far as possible so I can properly repair and conceal the repair.
                          Crusty old fuel injectors are going to get a few hours in a ultrasonic bath to loosen them up.
                          Vapor honing leaves a wonderful finish on aluminum, but its also extremely gentle with almost no abrasive nature. Even light surface corrosion, let alone anything else, won't get cleaned by the process. This means everything must first be glass bead blasted. I did a big batch today, more to follow tomorrow.
                          I bead blasted the differential input and output stubs while I was at it, then polished the sealing surfaces and gave them a fresh coat of semigloss black.
                          I thought I'd have a look at the clutch slave cylinder I'd pulled off earlier. It looked pretty shitty once I popped the star clip and picked the boot out.
                          Regardless I'd hoped I could save it, since its the original unit and all. Alas while I managed to free up the seized piston and blow the whole thing apart the cylinder bore is badly pitted in front of where the piston has been at rest. I'm sure s soon as someone depressed the clutch the boot would prolapse with fluid pissing past the piston seal.
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            I am sure I have an eta baro replacement for ya. Bear with me a few days, but it's yours for the cost of shipping. If you like, it can even be pin to pin wiring, but I am inclined to ask why not just use fresh wire snaked through the conduit and re-pinned to avoid a mid-harness splice?
                            john@m20guru.com
                            Links:
                            • Jordan
                              • 12916
                              Right on John, just let me know, I'm not in a rush.
                              Spent several more hours today glass bead blasting the rest of the aluminum castings to prepare them to be vapor honed.
                              • francogt1
                                • Sep 2011
                                • 269
                                You maniac you
