My e30 Project... Mtech II sedan, Jlines, Vaders, M50 and much more...
  • sticksdaman
    • Apr 2005
    • 2987
    #91
    moar!!!!
    Originally posted by ebelements
    Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
    • Vedubin01
      • Jun 2006
      • 5852
      #92
      nice man, I was wondering what had happened to the project.
      • amdspitfire
        • Mar 2006
        • 254
        #93
        how do you remove the cowl trim peices?
        • dj2xrated
          • May 2007
          • 540
          #94
          AAAH you just 'Inspired me to do the Rear Deck BLACK! like your way black not buy a stock one.. FUCKING SWEEET AWSOME!! i dont care how much it cost...in the end ...the before and after picture is all that counts
          Operation S/C E39M5.:woowoo:
          • e30 gangsta
            • 3877
            #95
            nice man real nice :)
            • motorsports_3
              • Mar 2007
              • 1058
              #96
              Thanks guys. I have been really busy and havent had much time to work on it, plus it has been way too hot.
              I have to finish the interior and put in the a/c compressor, and the parts left from paint, and the first phase is done.
              I didnt have much time today, but i had an oppertunity to chage the tie rod ends
              Jack up the car, and take off the wheel
              New tierods
              Old tie rod
              Loosen the top bolt
              Loosen the bolt in the back
              You can use a hammer, or fork to loosen the tie rod from the strut housing. Mine was easy to take off because i just did the shocks.
              Screw the new on in. Put it to about to where the old one was.
              Tighten the rear bolts
              Tighten the front one
              These are all the tools you need
              Tighten the wheel and you are done
              Now from other days
              I finished the rear deck.
              I put in the seat belt holder
              Cut out the factory holes
              Put in the vents
              Finished
              I put in the center console and speaker cover
              I cleaned the inerior with Degreaser, carpet cleaner and tide. It did nothing. My friends are telling me to paint the carpet, that dealers do it all the time. What do you guys think?
              Before
              After
              I got the license plate trim
              Here are the lowered pics of the car, it still needs to be settled and i will lower a bit more
              Thats it until maybe tommorow...
              • DEV0 E30
                • Oct 2004
                • 8904
                #97
                Where did you get this blood:
                The exact color I need for a set of wheels I have.
                Was it roadkill? Thrown on before pictures for artistic flair? I must know.
                Great work.
                • TwoJ's
                  • Oct 2005
                  • 4908
                  #98
                  overspray
                  Nice project man.
                  • motorsports_3
                    • Mar 2007
                    • 1058
                    #99
                    LOL, i dont really care much for the wheels. It is the brake quiet spray.
                    Great work.
                    • motorsports_3
                      • Mar 2007
                      • 1058
                      #100
                      Thanks for all your comments guys.
                      I fixed the a/c for the most part. I replaced the A/C compressor, messed up a little bit along the way. It cools to around 70 degrees, since it hasnt been used in so long I have to vaccum the system, and change the dryer. I will order the dryer today, and do the system vac today.
                      Look at the box it came in.
                      The new unit.
                      Get the car on jack stands
                      This is where it goes
                      Put the belt on the motor pulley
                      These are the only two bolts you need to put back
                      This is where i messed up
                      I tightend both of the bolts, You are supposed to leave them loose. When i tightend them there was too much stress on the tensionor. I striped the gears on the mechanisim.
                      You cant tell to well, but its stripped
                      My camera died in the middle, so i chared it and moved on.
                      Here is the compresor mounted
                      The gearing tension mechanisim
                      Run the lines
                      Tighten the lines, becareful as the compressor is alluminum, and so are the lines. Do not strip the threads
                      This is where you charge the system
                      Charging the system
                      The A/C temp at 70-75 degrees. It should work better once I am done.
                      • CorvallisBMW
                        Long Schlong Longhammer
                        • 13039
                        #101
                        As far as carpet painting goes, DO IT! Get SEM 'Color Coat' in whatever color fits best and have at it. I did my grey carpets and they look brand-fucking-new. Just spray on a coat, let dry, brush with stiff bristle brush to loosen. Repeat until desired color and finish is reached.
                        • Jean
                          • 18228
                          #102
                          Want to come over and do my A/C ? lol
                          Good work, what shift lever do you have in your car , it looks short ?
                          • steinbachphoto
                            • Aug 2007
                            • 914
                            #103
                            wow i just read every post, you've done lots of work on this!
                            http://www.steinbachphoto.ca
                            • mopower
                              • Apr 2007
                              • 24
                              #104
                              great work so far.
                              I need a new compressor! where did you find yours?
                              • e30 gangsta
                                • 3877
                                #105
                                did you create a vacum before putting that gas in there?
