What did you do to your E30 today?
This is a sticky topic.
  • red baron
    • 176
    #2221
    Pretty sure I blew my radiator hose. Waiting for it to cool so I can check it out.
    • bimmer_E30
      • 5001
      #2222
      pulled my left side foglight to inspect the light it was all good, what a bitch to take out though.
      helped my best friend pick up a late model Alpine white E30
      Originally posted by e30e
      • Conrad311
        • Oct 2009
        • 370
        #2223
        put a new windshield in, what a nerve racking job.. the whole time i thought it was going to shatter if i breathed on it wrong.. also "borrowed" a horn off a caddy thats in my shop so i can pass MA inspection today.. itll go back on the caddy tomorrow. probably. They have 2 anyway. haha
        "In God we trust. All others must bring data." -W. E. Deming
        /// 1987 325is /// Project Thread
        Past: 87 is, 88ix, 88 i, 87 ic, 89 ix, 17 others.
        • pelotudo
          • 158
          #2224
          yesterday:
          spark plugs
          air filter
          seafoam
          wiper blades
          today:
          oil change
          painted kidneys
          tomorrow:
          timing belt
          water pump
          thermostat
          coolant flush
          thursday/friday:
          front lip (hopefully)
          tucked DBs
          tint
          then driving it to MIA :)
          • supra89t
            • 30
            #2225
            I found a source for parts! I got all 4 inside door handles (with trim rings & screws), shifter boot, e-brake handle, defroster switch, driver mirror switch, 3 lock pull knobs and a used axle for $60.
            The right rear axle on my car was making some serious racket. I thought it was going to come apart on me while driving, so I picked up a used one to swap in. I had a 3.73lsd that came as an extra when I bought the car; I figured I would replace the 2.93open while I had the car in the air. I watched the guy pull the axle out of the donor car and I was very worried that I would have the same difficulty getting my axle out of the hub. Mine came out with a few gentle taps of the hammer. :) I guess I got lucky. One thing I did notice was that the replacement axle is a little shorter then the one that came out...about 1/4inch. There was plenty of play in the length, so I went ahead and installed it even though the joints felt a little stiff. Hey, if it comes apart, I have the old one. At this point, I don't know if the axle or the diff was the source of the noise. Either way, it is fixed.
            Actually, the whole thing went WAY easier than expected. I did have a lift, a tranny jack and air tools which made this a one-man job. Without those, it would have been much more difficult. Lining up the diff bolt holes without the tranny jack would have been nigh impossible. Once I got the 2.93 out, I noticed that it is most likely either completely dry inside or shot...turning an output flange felt like rubbing rocks together. The 3.73 was nice and smooth. I changed the fluid in the 3.73 while I had it on the bench with Lucas 75-90 synthetic. I am turning 3000rpm at 70mph which is a little high for my preferences, but the around-town "squirtability" makes up for it.
            Oh, and while I was in there, I went ahead and ripped my rusty old muffler off. The pipe>muffler weld had rusted through so the only thing holding it on the car was the hanger, fastened to the rear framerail with a 2" lag bolt. :hitler: I undid that and ripped the muffler off the pipe. Sounds MUCH better. I think I'm just going to get a pipe from pep-boys and clamp it on just to get the exhaust all the way to the back of the car before it dumps.
            Originally posted by mightywhitey
            tornado alley.
            Move from there if tornadoes are not your thing.
            • Atreus
              • 1846
              #2226
              applied meguiars leather conditioner to the seats, cleaned it up inside and out, took the shop vac to it, its pretty sleek an shiny now, now i just need to work on the exterior/suspension now lol.
              oh, and due for an oil change soon, 20 dollar special at advance auto for 5qts of castrol syntec blend 20*50 with a purolator filter....
              1991 325iC - Mauritsblau sumthin metallic blue. DEAD
              1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
              1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
              1991 325iC - Calypsorot Metallic
              1994 540i - Granitsilber
              Originally posted by scabzzzz
              I've had blunts cock in my mouth, but I'm not gay.
              • pelotudo
                • 158
                #2227
                :stupid:
                • xwill112x
                  • Jan 2009
                  • 4236
                  #2228
                  cleaned my interior for vintage at vineyards...
                  • David325e
                    • 32
                    #2229
                    Picked up a valve cover stud at the dealer, applied for job.
                    Picked up a bosch filter and jug of Mobil1 10w40. Thats what I've used in previous M20s, let me know if y'all have another suggestion.
                    If it doesn't stop raining soon I'm going to the shop. Todays Agenda:
                    Fuel filter
                    oil/filter
                    valves
                    Run bentley tests for tps and some similar parts.
                    Fill up and add stabil.
                    • duboy
                      • 83
                      #2230
                      replaced the blower resistor in my 318is (surprisingly no crap jammed up in there on the fins, and for the most part pretty clean), yay for working blower/AC
                      on sunday i put in a german OBC in my M3
                      | '89 M3 | '93 M5 | '03 X5 4.6is | '03 325i | '87 190e 2.3-16 |
                      • bimmer_E30
                        • 5001
                        #2231
                        got all the scratches off, debadged and recieved my 2 wheels and 4 tires, now waiting for the other 2 then going to install them.
                        • dashboardmonkey
                          FUCK YOUR WAFFLES
                          • Jun 2008
                          • 6158
                          #2232
                          came into the drive wau too fast and clipped the air dam. bent up my front fender.
                          -Andy
                          • a3ternus
                            • 643
                            #2233
                            Did a minor tune up to the M10 w/headers!
                            I mean valve adjustment and checked the engine timing!
                            What a difference that made to the way the car goes!
                            Its been 2 years since my last one and cost just 25$! ;)
                            N.
                            Originally Posted by aaron_silva
                            It is always frustrating having a harsh ride when
                            you arent in the right mind set.
                            • supra89t
                              • 30
                              #2234
                              Put in a 24" section of tailpipe to replace the muffler that I ripped off (with ma baer hands!) this weekend. Painted the pipe with flat black grille paint so it wouldn't look like a Midas special. She sounds good. The factory cat does a ton to muffle the exhaust. It's the best $14.39 I've spent on this car.
                              tornado alley.
                              • kamotors
                                • Nov 2007
                                • 7102
                                #2235
                                Drove it around just because I love how it sounds:)
                                7speedshop.com
