What did you do to your E30 today?
This is a sticky topic.
  • e30nub
    • Jun 2008
    • 1741
    #2416
    Pulled my whole interior to clean and condition it. Going to go buy new clips today since I'm tired of all the rattling. Also greased up my windows so they are a lot smoother.
    Does anyone know how to get that black glue shit off that holds together the door insulation to the door?
    -Pierre
    1987 535is
    1988 325is
    • bimmer_E30
      • 5001
      #2417
      plastic razer blade+ some adhesive Remover ^^
      i waxed her and going to take apart my foglights.
      Originally posted by e30e
      • 8380 Labs
        • Oct 2006
        • 2990
        #2418
        Originally posted by E30is90
        2. Replaced lights behind fan speed dial, temp dial and above headlight/fog light switches.
        what's the procedure for this? mine just went out a few days ago.
        today:
        1) replaced tranny fluid
        2) ground down rear lug bolts
        3) finished disassembling RSs and polished the rear 2 lips
        8380 Laboratories
        M3 Champs Poster
        • evil_twin
          • Nov 2007
          • 2965
          #2419
          got my akg delrin bushings for the shifter. i pulled the bitch clip out of my 24v swap, what a pain in the ass. and i took my shifter carrier out as well as my intake manifold.
          Paypal: vdang5@gmail.com
          Delta Auto Care
          2875-C Towerview Road
          Herndon, VA
          703.435.1375
          My Feedback Thread: Evil_Twin
          • E30is90
            • Jul 2010
            • 107
            #2420
            Installed new after-market Fog Lights (i.e. Chinese no name eBay special). They look good enough after installation, but what a bitch getting them to work!
            Had to mount the gasket, no problem there.
            Put on clear urethane shields to keep them from pitting and being sandblasted, no problem there.
            Installed them under the valence and found that the right side connector socket was a mirror image of the left with the flat and round sides reversed (the slot was in the right spot) so the plug housing wouldn't go in. Couldn't even reverse the wires, had to pull the plug pins out of the housing and force them onto the mating pins. What a boneheaded fuck up. Just goes to show what happens when someone tries to knock off the original design. But hey, for a shipped set at $74.99, I can't complain too much.
            Then after all was said and done, the lights didn't work! I had to pull them out and check the wiring within the fixture. It turned out that they painted the metal plate that acts as a ground and insulated the ground of the bulb. Another boneheaded fuck up. I had to scrape off the paint to expose the bare metal and solder the tab to the pin to get continuity.
            Back in the car and all is well. They do look good enough from the front. I guess that's the important thing.
            over 240,000 miles served
            original owner since Oct. 31, 1989
            • E30is90
              • Jul 2010
              • 107
              #2421
              I had actually posted the procedure for the headlight/fog light switch illumination just a few days ago. Below is a link for both procedures. Good luck!
              • Holland
                • Nov 2008
                • 7212
                #2422
                Tune up and a new V-belt.
                Originally posted by DEV0 E30
                • sonej4
                  • 90
                  #2423
                  Exhaust manifold gaskets.
                  • dr.strangelove
                    • Jan 2005
                    • 847
                    #2424
                    Fixed the reverse light wiring on the M3, and mounted the euro grills
                    • Gerta
                      • Sep 2009
                      • 2119
                      #2425
                      Fixed broken hood release cable ... cleaned the hood latch so now no sticking. Also re wired depo US elips ... PO of the car did a crappy job with those.
                      Parts Collector and Former Houndstooth interior junkie.
                      • Ziggy
                        • Jul 2010
                        • 12
                        #2426
                        drill holes in my diving board bumper dampers and drive into a wall!
                        looks much better
                        • Jand3rson
                          • 37587
                          #2427
                          Washed it, and just spent a half-hour in the garage with polishing compound getting the paw-print scratches from neighborhood cats out of my hood.
                          • ak-
                            • 12422
                            #2428
                            Installed hubrings.
                            No vibrations at 50mph anymore!
                            1991 325iS turbo
                            • ecoviper9
                              • 65
                              #2429
                              New clutch, flywheel, oil pan gasket, rear main seal, 2 CP sensors, deleted driver side highbeam, new throttle cable, removed fog lights, tuck, euro grlz, tags, and lots of break cleaner.
                              • ThreeTwentyFissel
                                • Apr 2009
                                • 220
                                #2430
                                Stared her down in that crazy stance she sits!!
                                Simplicity is your best option!
