What did you do to your E30 today?
This is a sticky topic.
  • dinanm3atl
    • Feb 2007
    • 7305
    #4186
    Busy weekend... then racing next weekend!
    • e30edward
      • 777
      #4187
      Painted the door trim and door handles. Removed the old alarm the PO had installed. Removed the antenna that would never retract and put a rubber grommet in it's place.
      • deutschman
        • May 2008
        • 5958
        #4188
        dropped the e off at A1 Imports
        • Herr Faust Schinken
          • Feb 2012
          • 3580
          #4189
          Rain-xed the shit out of it cleaned the interior started it turned it off then walked back inside
          88 325is Five Speed
          Lachssilber
          • canakami
            • 743
            #4190
            Finally got the thing registered, passed smog with flying colors(surprised me to be honest) shortly after figuring out an idle issue.
            New focus of annoyance: Oil leak, most likely cause by a crap helicoil job on the oil drain from the p.o.
            Always chasin'
            • canakami
              • 743
              #4191
              Got a new key cut off the VIN#.
              Apparently the locks/ignition have been changed cause the key doesn't do anything.
              Always chasin'
              • dustt31
                • Jul 2008
                • 13
                #4192
                Went to dyno. Got dyno tuned.
                :giggle:84 325e- M20b27, Garrett T04e divided, VAC turbo cam, 3.25S, MS2e. SLR angle kit. :giggle:
                • CHIF8008
                  • 3447
                  #4193
                  new rear tires and took this:
                  And made it to be able to do this:
                  -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
                  -The Beauty in the Tragedy-
                  MECHANIC SMASH!!- (you all know you do it)
                  Got Drop?? ;-)
                  But of course
                  E30s are know to be notoriously really really really ridiculously good looking
                  • Javierocks
                    • Jun 2012
                    • 84
                    #4194
                    Install the air dam & a quick wash[IMG][/IMG]
                    • FAs
                      • Jun 2011
                      • 95
                      #4195
                      Donuts
                      FAs
                        • Feb 2012
                        • 3580
                        #4196
                        Drove down highway 38
                        88 325is Five Speed
                        Lachssilber
                        • Rose E30
                          • Jun 2012
                          • 113
                          #4197
                          I love the stickers, looks sick!
                          Zinno 87 325iS
                          • bimmerpirate
                            • Feb 2007
                            • 561
                            #4198
                            installed new tires and tore apart my old insturment cluster to get all the parts and euro goodies ready for my new e30's instument cluster. like fresh gears, euro gas gauge and light bar filters.
                            tomorrow things get interesting with it.
                            • Rose E30
                              • Jun 2012
                              • 113
                              #4199
                              fixed the rear trunk light on a whim. Turns out the switch that senses if the trunk is closed was not connected to the light. reconnected and good to go again!
                              Also used JB weld to fix the plastic frame that sits above the headliner and holds the door lights in. Worked wonders, what would I do without it?
                              Zinno 87 325iS
                              • e30edward
                                • 777
                                #4200
                                Started to remove the cruise control system. Was only able to remove what was in the engine compartment before it got dark. Will have to do the wiring another day. Once I got everything back together and went to roll up my windows...they wouldn't work. Not sure what it was since I had the battery disconnected the whole time, but I just swapped an extra window switch I had and they worked haha.
