I fixed an oil leak I had.the oil pressure switch was done...a bit of a pain to remove...but I'm glad to see a clean bottom for once and no oil everywhere I parked...I still have to figure out why my engine oil light still on my warning panel and coolant light too.
What did you do to your E30 today?
This is a sticky topic.
Replaced wheel bearing and swapped exhausts and ox sensor. passed smog and finallu registered.
Sent from my SPH-D710 using Tapatalk 2Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
89 E30 S52
Transaction Feedback.Comment
fixed my extremely high idle (4500-5000+ RPMs)
and it was not my torn intake boot :tsk: looks like a knife job. but who?
it actually ended up being the wiring to the ICV on my ETA. swing the wires left and it ran and idled just fine- then go the other way, and it surges like a MoFo-FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
-The Beauty in the Tragedy-
MECHANIC SMASH!!- (you all know you do it)
Got Drop?? ;-)
Originally posted by JinormusJBut of course
E30s are know to be notoriously really really really ridiculously good lookingComment
oil in a European car is very touchy- and if your above or below the fill line it may turn on the check light.
coolant light is more than likely(if you have no leaks) that the sensor in the tank is just old and defaulted.-FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
Got Drop?? ;-)
The oil is right a the 2nd line and could it be that the plug that goes to the switch might be out? Since it was shower in oil do to the leak I try to clean it and let it dry as much as I could..I'll hopefuly be replaceing the colant level sensor this weekendComment
After two days finally finished trimming my quarters so them 17"'s finally tuck with just a waffleswaffleswaffleswaffles hair to spare.
Had one of my bent rims repaired. Only $40. Polished my rear lips.
Took it for a joyride!!Comment
Fixed spark plug wires added some oil and tightend the bolts on the shock tower that were a bit lose88 325is Five SpeedLachssilberComment
Finally made time to go over to my friends place (3hrs. one way by stupid public trans). Re-did my botched water-pump/timing belt job. Ran her nice and hard through a favorite road of mine on the way home.
Crossing fingers for smog tomorrow morning...sigpic
Always chasin'Comment
DREWLIENTE
