What did you do to your E30 today?
This is a sticky topic.
  • M-technik-3
    • 18946
    #4696
    Replaced the starter.....turns out the new one is non functioning as well. Hate wasting my time.
    • ak-
      • 12422
      #4697
      That really sucks, lol.
      So I was doing my thing and some how did this:
      So I called AKG for warranty, and they were nice enough to give me this:
      And I just finished doing this:
      I'm a happy camper.
      1991 325iS turbo
      • M-technik-3
        • 18946
        #4698
        Yeah mine was dropped shipped from Bosch too. So now I have two starters to send back.
        • Bimmer_man
          • Jan 2013
          • 1477
          #4699
          I tore my passenger door apart to see if I could fix my Window regulator. Found out it needs replacing. Also found out my door cards are fucked. Time to switch to different cards. Gonna try to get black door cards with cloth inserts for my 4 door.
          Float like a cadillac sting like a Bimmer!:)
          • rzerob
            • Jun 2013
            • 2315
            #4700
            Started putting my freshly powder coated trim back on. Putting the trim back on rear side windows is a PITA. Got aother tweeter for the driver side. And A/C lines and receiver dryer. Hopefully A/C in a couple of weeks.
            • rzerob
              • Jun 2013
              • 2315
              #4701
              I got the windows back in. Soldered in an inline fuse. And started it up for the first time in a long time. Sounds good. Still piecing together my exhaust. Looked for more much needed parts. Got a steering wheel washer.
              • rzerob
                • Jun 2013
                • 2315
                #4702
                Driver side weather stripping(around door frame)replaced. Installed new to me Driver side door sill. Installed purge valve.
                • SeatownE30
                  • 594
                  #4703
                  Absolutely nothing :)
                  1991 318i Sedan
                  2005 X5 3.0i Sport
                  2010 328i M-Sport Touring
                  • lambo
                    Captain Scene Points
                    • 10953
                    #4704
                    Broke my selector rod lol
                    • CHIF8008
                      • 3447
                      #4705
                      where im at right now. still lots of cutting left before it will be fitted.
                      top edge will sit down about an inch(gives room for welding and structure) using halves from a spare tire well we cut off a 318
                      -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
                      -The Beauty in the Tragedy-
                      MECHANIC SMASH!!- (you all know you do it)
                      Got Drop?? ;-)
                      But of course
                      E30s are know to be notoriously really really really ridiculously good looking
                      • Reichart12
                        • Aug 2012
                        • 2165
                        #4706
                        I went to a car show at a local pepboys and won two free pulls on a dyno they brought in. My cars a 1986 325e with an ebay chip and somehow it was able to do 110hp with 146 ft/lbs. I was pretty happy about it.
                        Instagram: Reichart12
                        • rzerob
                          • Jun 2013
                          • 2315
                          #4707
                          I installed my skid plate. And then scratched it. I also got to drive it again for the first time in about a month. I love this car. Fan didn't work, I have to replace the fan relay.
                          • deutschman
                            • May 2008
                            • 5958
                            #4708
                            Finished my Hella fog light wiring and found a fun place to put the switch that does not require drilling holes into any part of the dash. The cigaret lighter of cores. I dont smoke and I dont need any 12v sores for charging as my head unit has a USB port, so this is perfect for me. With a bit of work with some needle nose pliers and a sharp blade the button Hella supplied with the lights just popped right in!
                            • rzerob
                              • Jun 2013
                              • 2315
                              #4709
                              Worked on installing trim pieces. Dropped a nut down in the a pillar, so I had to take the rear side card out to find it. Worked on my horn. Bought a new muffler.
                              • lambo
                                • 10953
                                #4710
                                Cried while wishing I could drive it...
