What did you do to your E30 today?
This is a sticky topic.
  • bernzpeed
    • 3917
    #4846
    S5X-fied mine. Heard her crank. Will be running soon.
    89 E30 S52
    Transaction Feedback.
    • gnarsteezman
      • Sep 2013
      • 51
      #4847
      shadowline, twas a bitch
      • lambo
        Captain Scene Points
        • 10953
        #4848
        Pulled something in my back...
        When did I turn 50??
        • henryki
          • Jun 2013
          • 960
          #4849
          A/C and Power Steering Delete, why? Because race car!
          electric fan swap to come next, anyone got any suggestions for what kind of fan and how to make it work with the ac button inside the car? Thanks
          • Madhatter
            • Oct 2004
            • 966
            #4850
            Spal and flexalite are a couple I know of that make genuine 3000cfm thermofans. Personally, if you are running a race car, either wire in a thermoswitch and let it control the fan on and off, or just wire it in so it runs permanently with the ignition on. You don't want to have to worry about switching on a switch in a race car, easily overlooked one day and it could cost you the motor.
            Just a little project im working on
            - http://www.lse30.com -
            • henryki
              • Jun 2013
              • 960
              #4851
              Sweet thanks for the info. It's just a street car I was just being sarcastic haha, but i want the ability to turn it off when I'm on the freeway and on when I'm on the streets
              • e30m3s54turbo
                • Jun 2010
                • 3284
                #4852
                Today I finished putting on chrome bolts on my last Hartge wheel.
                • Madhatter
                  • Oct 2004
                  • 966
                  #4853
                  I'd still install it properly with a thermoswitch and let it turn the fan on and off when the car is hot enough.
                  • henryki
                    • Jun 2013
                    • 960
                    #4854
                    Cleaned up this mtech 1 wheel. Like brand new now!
                    Took this garbage off.
                    And put this on
                    thanks to Pantless Spency for the wheel!
                    • E30Jigzaw
                      • 1197
                      #4855
                      Polished the rear window .. Started detailing her for Archie's ;)
                      Buy e30 cup holders
                      http://www.r3vlimited.com/board/show...41#post4159541
                      Buy BMW Motosports handles
                      http://www.r3vlimited.com/board/showthread.php?t=302846
                      Buy BMW MOTORSPORT valve covers http://www.r3vlimited.com/board/showthread.php?t=330146
                      • mkcman17
                        • Jul 2010
                        • 8240
                        #4856
                        Painted my car
                        1989 LN106 Hilux / 3.0TD SFA
                        1974 2002tii / stock
                        2002 IS300 / 5spd LSD
                        • Madhatter
                          • Oct 2004
                          • 966
                          #4857
                          started to have a good look at the spot of rust in the battery area in the boot. Was a round hole about an inch in size, till I stripped back all the seam sealer off the valance and got the wire wheel out. The joins in the sheet metal were the first bits to go, opened up totally. Probably started with a leaking boot seal or tail light gasket. Annoying that the previous owner just kept driving around while his boot filled with water.
                          Will have a look at the other side tomorrow before going to the wreckers for some replacement pieces. Reckon they'll mind if I turn up with my own plasma cutter? :D
                          • ikonwun
                            • Apr 2012
                            • 374
                            #4858
                            Well it's hard to follow that!!!
                            Pulled my rack banjo bolts and fill welded the holes!!
                            Free powersteering delete..
                            • cabriodster87
                              • Jan 2011
                              • 1042
                              #4859
                              I thought that with ps delete those should be open to allow for pressure transfer between left and right turns.
                              Reich und Roll!
                              • ikonwun
                                • Apr 2012
                                • 374
                                #4860
                                Not when the rack has no fluid in it.
