Originally posted by iflytii
View Post
My e30 DTM car copy build
the tilton pedals will be mounted at least 4" past that bar. I like having closer pedals as i will get more leverage on them since i will be running manual brakes and racks. so im not to worried about the bar. yea the car is hacked to shit, but i have another e30 cut to peiced for all the cut up spots, so im not to worried about that.I wanna go Fast
I'm interested in seeing the end result with those pedals installed. I like my tilton pedals and I think you will find they don't take as much effort as you would think.Originally posted by ///meric View Postthe tilton pedals will be mounted at least 4" past that bar. I like having closer pedals as i will get more leverage on them since i will be running manual brakes and racks. so im not to worried about the bar. yea the car is hacked to shit, but i have another e30 cut to peiced for all the cut up spots, so im not to worried about that.
Have you tried your dimple dies yet? What are you using or planning on using to form with? I found that a semi-cheap arbor press works great with them.
are u using the floor mount, or the firewall mount because the floor mount have a lower leverage ratio, im going to get some tubing bent a nd mount them to the cage
As for the press idk what im going to do. I can not stand cheap tools, if i buy a tool i get something that will last, so i will more then likely end up with one of these http://www.tricktools.com/sheet_meta...or_presses.htm
otherwise
i will make my own hydro version of the above press.
i may be lazy tho and get one of these
The Dake B10, 10 ton shop press is a utility H-Frame Press with a fast, efficient, single-speed hand pump, and a large diameter, single-acting piston.
either way it will need to be strong as i will be using up to 4140 1/8" plateI wanna go Fast
I don't mean to hijack, but how did the pedal installation go?Originally posted by iflytii View PostI'm interested in seeing the end result with those pedals installed. I like my tilton pedals and I think you will find they don't take as much effort as you would think.
[Thread_Hi-Jack] Went well! Had to modify the throttle linkage but other than that it was a lot easier than I had anticipated. I made a simple bracket that tied the pedal assembly to the front bulkhead for additional reinforcement. You can't see in those pictures but the dash bar is right above the steering support and is tied into the front bulkhead. I had to modify the throttle linkage a bit by removing the lever arm and welding a new one that moves the cable location further to the right (aluminum part to the right of the balance bar)Originally posted by Mike B. View PostI don't mean to hijack, but how did the pedal installation go?
[/Thread_Hi-Jack]Last edited by iflytii; 11-25-2007, 07:22 AM.
I dont want to sound like an ass, but i would tie those mounts into the cage, Even tho it is tied in like it is stock, since it is fully manual there is alot more force going into those mounts, nothing worse then not haveing a ridgid brake mount.Originally posted by iflytii View Post[Thread_Hi-Jack] Went well! Had to modify the throttle linkage but other than that it was a lot easier than I had anticipated. I made a simple bracket that tied the pedal assembly to the front bulkhead for additional reinforcement. You can't see in those pictures but the dash bar is right above the steering support and is tied into the front bulkhead. I had to modify the throttle linkage a bit by removing the lever arm and welding a new one that moves the cable location further to the right (aluminum part to the right of the balance bar)
[/Thread_Hi-Jack]
Bad new tho, it looks like i wont have much time to work on the car much, as its xmass time and i work in retail. and stupid finals. But after xmass i have a week of just me and the car planned, im gonna go and order a bunch of tools so that i wont have to stop for anything.I wanna go Fast
