My Garage Build
  • golde30
    • 11464
    #46
    too bad the ceiling is so low, you could have put in a lift...
    IG: @Baye30
    • atomic
      • Jun 2007
      • 5691
      #47
      Why did the builder use 4x4 post and header system with furring strips to attach the subsiding on instead of conventional stud framing like most homes and general construction are built. Just curious... as pressure treated lumber fixed in the ground with concrete WILL rot quickly.
      • jakeb
        • 1909
        #48
        They make lifts that work with lower ceilings...
        It is a pole building....The posts are made to be in contact with the ground.
        www.classicdaily.net
        1970 m42 swapped 2002
        1985 LS1/T56 Swapped e28 (557e)
        www.blunttech.com - For all your parts needs
        Follow me on Instagram for constant build updates @classicdaily
        https://www.facebook.com/ClassicDailyLLC
        • Hartge_H27
          • Jun 2006
          • 1699
          #49
          i want it. looks good.
          • PiercedE30
            • Apr 2005
            • 4220
            #50
            Is your table top a SOLID piece, of what looks like 5/8 or 3/4, stainless plate?
            My 2.9L Build!
            • jakeb
              • 1909
              #51
              No it is not solid stainless. The top is about 1" thick with steel or something HEAVY and then wrapped with stainless.
              • Disaster Inc
                • Oct 2007
                • 429
                #52
                Originally posted by jakeb
                [/img]
                Get that lawnmower out of there asap! It has no right to be taking up space in there.
                • OrganicMechanic
                  • Jan 2008
                  • 1719
                  #53
                  no matter how big it is latter you will need bigger. First lift, then weld bay
                  join the E30 Cabrio owners gruppe
                  click here for details
                  • scabzzzz
                    Estado de mierda de encargo
                    • 6871
                    #54
                    Plans for a couch and stripper pole? How many LCD's will be installed?
                    Looks sweet as fuck. High five.
                    • monty
                      • Feb 2007
                      • 665
                      #55
                      Any progress? Lets see some cars being worked on in there.
                      • jakeb
                        • 1909
                        #56
                        I will snap some pictures of what is in the garage.
                        For about 2-3 weeks I could actually fit all 3 cars in. Then I bought a bunch of 02 parts and now the e30 is out in the cold again. Should change soon as i have sold a bunch of them and making room.
                        the 2002 will be getting volvo front brakes and VW rear discs soon. Also going to re do the interior soon. Should be a lot nicer.
                        • TrentW
                          • 2815
                          #57
                          How about an update? I'm curious how you're heating your garage--I used a bazooka kerosene heater last winter, but it's loud and kerosene ain't cheap. Researching the best option that won't cost me a small fortune.
                          • Nicademus
                            • 2912
                            #58
                            You should stain the concrete and make it look all purty, plus it makes it less stain prone and easy to clean. Its easy to do it yourself too.
                            Like this or whatever color you'd like (basically anything you can imagine):
                            Well, posterity, you will never know what it cost us to preserve your freedom. I only hope that you will make a good use of it. If you do not, I shall repent in heaven that I ever took half the pains to preserve it.
                            ~ John Adams ~
                            • idriverealslow
                              • Nov 2009
                              • 49
                              #59
                              wow ive never seen that. thatd be dope
                              • TrentW
                                • 2815
                                #60
                                That is cool, but you'd have to use a clear epoxy sealer to keep oil, gas, coolant from damaging it and also some texture so you don't end up with a skating rink when it's got a layer of oil on it.
