!!!!!Caution M20 porn inside!!!!!
I've got a short video uploading right now of the ITB's in action, I'll post it as soon as it's done loading
Hey Dominic49 I moved the pick up point 1" and had a 1/4 diameter steel rod welded in to help reinforce it. Then I just used some high strength m12 threaded rod and threaded into the stock clevis, and ground the end that goes into the master cylinder smooth. I'll see if I can snap a pick under the dash some day for you.85 325e 2.7 ITB'd stroker
Ok here is the video, I really need to change out the heavy ass eta flywheel that is still on the engine, as the revs stay up there forever before dropping back down.85 325e 2.7 ITB'd stroker
Ya, if you've got those sweet-ass ITB's you def need a lightweight flywheel. I find the 15lb single mass from a euro e30 323i works very well :) Of course there are numerous aftermarket options toohttp://video.google.com/videoplay?do...72648717105027
EDIT: just watched the movie with sound, and you're not kidding! that thing holds on to revs like it was in gear coasting! get a ltw flywheel asapComment
thanks again. i'm going to go for a simalar setup on my m62 swap. :D how do the brakes feel? need better leverage?Comment
LOL, valves so loud. Need some action video of it doing some work. You got a parts list?Comment
Ely, awesome work.Comment
I love it!!! Keep at it :)Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
