Labor of love from Australia - Malachtgrun convertible running restoration
  • e30m3s54turbo
    • Jun 2010
    • 3267
    #136
    I like your project…
    • Tzantushka
      • Nov 2018
      • 389
      #137
      Thanks - keeps the mind working!
      Also fixed the recurring cooling check control panel light.
      Had nothing to do with the sensor or the panel.
      The plug housing kept coming loose from the sensor - because of:
      Crumbling rubber insulation around the connector buckets
      Managed to fix that with a few wraps of insulation tape and then a sheath of 4:1 heat shrink tube.
      Now the connector buckets are nice and snug in the plug housing and the plug stays put.
      E30 320i vert
      But daily drive is Volvo V60 Polestar
      • Northern
        I like cupcakes & sh!tboxes
        • 5234
        #138
        Honestly, that's a pretty slick fix.
        Always hated this style pin with the moulded end piece they use all over the body.
        Pain in the ass to replace to because you can only buy replacements as a pigtail, and I think straight and in green?
        Originally posted by priapism
        Originally posted by shameson
        • Tzantushka
          • Nov 2018
          • 389
          #139
          Thanks - if the connector is fine and the rubber insulation is stuffed, I don't like spending $$ to replace something else.
          Meanwhile, in other activities - gave the carpets an out-of-car deep clean.
          Has been on the list of things to do for a while, but needed a good run of warm weather to properly dry the carpet as the foam is moulded to the carpet.
          Pressure washer & scrub, repaired some of the flaking rubber backing & foam.
          Floorpan was in remarkably good shape - also gave the floorpan a coating of Penetrol for protection in case of moisture ingress...
          Stuck with the Duplicolor Medium beige used for door cards & kick panel...
          Light coats in a cross-hatch pattern & agitate the carpet nap to retain the fluffiness.
          Turned out darker than expected.
          But still a marked improvement from the faded carpet.
          Also a good opportunity to install the DAB antenna for the Bremen head unit.
          And also run a new FM / AM antenna cable, as the OEM cable had been cut & poorly spliced from a previous life.
          Was able to buy a complete cable with the Hirtschmann connector - so the reception is now 10x better.
          For our Australian viewers can buy them here from Sound Labs
          E30 320i vert
          • econti
            • May 2014
            • 1143
            #140
            Where did you get the head unit from? SQR-46, right? Been pondering which to get for my MR2, and its on the list.
            • Tzantushka
              • Nov 2018
              • 389
              #141
              Yep, Blaupunkt Bremen SQR.
              From memory bought it from Strathfield online (when they had their sale)
              E30 320i vert
              • rjmcdermott81
                • Oct 2014
                • 567
                #142
                That carpet looks incredible.
                Build Thread: Ryan's Hennarot 318is
                COTM Aug 2019
                • Tzantushka
                  • Nov 2018
                  • 389
                  #143
                  Thanks. I was hoping to replicate something the same colour as the door cards (also Duplicolor medium beige) but for some reason it was darker.
                  It's growing on me though. Will need to take some pics with everything installed and under normal light.
                  The seat leather is the only thing that's not quite right colorwise, but they are in reasonable condition.
                  I can live with that for now.
                  E30 320i vert
                  • Tzantushka
                    • Nov 2018
                    • 389
                    #144
                    Oh, and also forgot to mention, after 3 and a bit years, was getting a few drips of oil on the floor.
                    Turns out the rocker cover gasket was tired - tighten-up of the nuts didn't solve it - so it was cover off, clean-up & new gasket / plugs.
                    Everything was pretty clean & tidy after the head was done in mid-2021.
                    Cleaned the mating surfaces of the head & rocker cover.
                    Gave the rubber plugs a thin smear of Permatex ultra black RTV and tightened the rocker cover nuts as per the Bentley manual.
                    After a few short runs to do errands, everything looks pretty tidy.
                    Will check gain in a few weeks.
                    E30 320i vert
                    • Tzantushka
                      • Nov 2018
                      • 389
                      #145
                      Minor update - while you guys are enjoying the nice weather, we have the rain down here.
                      Which means the windscreen wipers are getting a work-out on our cold winter days.
                      I was experiencing slow & juddering wipers when using the single sweep & intermittent functions.
                      When things warmed up and after several sweeps the med & fast settings were OK.
                      I followed this excellent write-up in the E30 Zone Wiki,
                      https://www.e30zone.net/e30wiki/inde...n_Wiper_faults
                      Here are some pics for inspiration.
                      Linkage was good, but the passenger side spindle (RHD) had seen better days...
                      Part Number 61611353754 (Damper ring)
                      Motor & splash shields out for cleaning & inspection...
                      Yep, inners were gunked with solidified grease from the worm gear...
                      Some paper towels, electrical contact cleaner & gentle scrub with a toothbrush - all clean.
                      Replaced the worm drive grease (just used high temp bearing grease I had handy) and a thin smear of dielectric grease on the face of the contact rotor...
                      Connector was also cleaned-up with the vinegar + salt and water + baking soda solutions (here)...
                      (Dielectric grease on the pins to help minimise corrosion)
                      Ready for installation!
                      Few things I learnt along the way:
                      • after disconnecting the linkage, loosened the 3 motor mounting bolts and THEN the bracket nuts - the bracket stayed in the cowl, triangular splash shield & wiper motor out through the blower access panel
                      • dielectric grease for the female connector as well
                      • I didn't follow the reassembly process & had the wiper arms swipe down toward the engine - make sure you install the linkage at the uppermost sweep position.
                      • good chance to clean out the cowl & elephant trunk drain (vacuum debris and then soap suds with paintbrush & compressed air
                      E30 320i vert
                      • Mike36
                        • 1079
                        #146
                        Lots of good info here, thanks for documenting everything.
