Part you hate removing
    Title says it ALL, I will start: Trailing arms(let me explain)
    Back story:
    I am selling my DD to a member and the rear bearings are toast from tracking. So I bought new ones to replace them. Turns out they are froze solid(puller and impact) So bought arms from a 91 318is. New bearings and SMOOTH as can be.
    Onto the HATE:
    So got the axels out and cables/lines disconnected. Here is the HATE, rear trailing arms that have solid frozen bolts. Nothing I could do, heat/impact nothing would get the bolt to move. Nuts came off easy. So long story short I had to drop the whole FUCKING subframe. No way in the world was I blowing the heads off with the torch =)
    So I hate trailing arms more than ANYTHING on the e30. I have pulled and swapped an M20 in 5 hours. Spent 6 hours hitting walls when I should have just dropped the rear.
    Edit: I have removed the subframe from every e30 I have owned. This one was a fucking nightmare...
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    heater core. such a bitch.
    m106 1990 e30
    e36 daily
    e32 cruiser
      Anything related to the rear suspension. Subframe, trailing arms, rear wheel bearings, e-brake, diff, half shafts.
      I hate it all.
        Headliner and rear, non pop out glass. Everything else is cake.
          I hate it all.
          that's funny... it was my first time taking them all off and i didn't have any problems at all. took the trail arms off first, then the subframe with a jack on the diff.
          now putting them back together might be a different story.
          89 E30 S52
          Transaction Feedback.
            ignition key.
            Lorin
            The M30 is God's engine.
              Try doing it in NY with a rear that has never been touched. I bought one from cali as my track build. SO EASY, everything came free and I fell in love =)
              P.S. The e30 I am working on has never seen a winter. I have no clue how those rear bolts became solid.
              Current cars:
              ~ '87 535
              ~ '06 X5 4.8is
                I hate taking off my starter.
                I always have to take the intake off because I cant get to it.
                84 318I Delphin RIP
                87 325IS delphin 24v Sold
                89 325 Alpineweiss
                  my rear subframe SUCKED and then we did my friends rear subframe and it took sooooo much less time.
                  09/1989 325i 4 Door
                  +M30 Swap
                  +Z3 Steering Rack
                    My oil pan. In cold ass raining weather. Most miserable time of my life to date.
                    out dated sig is out dated
                      heater core
                      tasty
                        Rear wheel bearings.
                        Mainly because the half shafts were seized in the splines. I hit one with a 20lb sledge for 45min and it didn't move..
                        I then went to Home Depot and rented a Hilti electric jack hammer.
                        It moved.
                          try changing out an engine in the rain. then you kids can bitch.
                          farbin. back me up here.
                            I dont understand how some people can't get 2 joined items to separate. I've never come across something that I wasn't not able to separate. Air hammers, hydraulics, acetylene torches, bfh's, and will power always work. Also a small knowledge of mechanical engineering physics can help (understanding deformation, metalurgy, etc.)
                            Ma che cazzo state dicendo? :|
                              Originally posted by LJ851 View Post
                              ignition key.
                              really? that is the easiest thing ever. put key in. put thin metal object in (i used a finishing nail from a nail gun.) turn key. tap metal object with a hammer. done.
                              it just pops out.
                              AWD > RWD
