So I dropped my 24v in over the weekend, and have some time to mess with it today so I decide to stick the driveshaft in:
![](https://c4.staticflickr.com/8/7789/18150410506_4acbc9e804_b.jpg)
Oh wait, why does it look like the driveshaft isn't straight? Probably because it isn't.
Everything I read about using the E36 driveshaft says to get an E30 CSB and install it backwards.
I don't know who the crackhead was, or why they decided it should go on backwards, but they're wrong. The offset E30 CSB bolts to the offset mounts on the E30 trans tunnel to center the driveshaft at the CSB. If you flip the CSB, instead of cancelling out the two offset parts, they add together and your driveshaft is way off.
Driveshaft was almost fully installed, only the CSB to go. It was great timing to piss me off.
I could've left it, but future me would have been mad when it failed...
It was kind of a bitch to remove and re-install without damaging it, but I managed it. In the process I pulled the whole rubber/mounting part off of the actual bearing and found that it's just loosely pressed on. I guess it's supposed to be preloaded so it doesn't work its way off the bearing.
I'm pretty salty about this right now.
