Nonsense Thread
  • Holland
    • Nov 2008
    • 7212
    #5071
    Glad to see a lot of you guys are still here.
    Oh, and the E30 just sits in the garage now...
    Originally posted by DEV0 E30
    • rturbo 930
      • Dec 2005
      • 2629
      #5072
      Well would ya look what the cat dragged in...
      Welcome back.
      • ThatOneEuroE30
        • Dec 2013
        • 8626
        #5073
        Holy blast from the past. Good to see ya back man. Whats up with the e30 sitting in the garage!
        1991 318i 4dr slick top
        Mtech 2 turbo restoration
        • Holland
          • Nov 2008
          • 7212
          #5074
          Welcome back.
          Haha! Thanks. it's been a long time for sure.
          I'm slowly, and I mean really slowly, acquiring parts for my 24v swap.
          • Exodus_2pt0
            • 5943
            #5075
            The railroad has changed me. In my 10 years as a tech I never considered rebuilding an alternator.
            Alternator took a shit on the S4, so I decided to investigate since a new OE unit is $600. Took off the voltage regulator, worn brushes. Found some brushes that fit with a little filing, soldered them in, boom. Fixed for $6.
            No E30 Club
            • flyboyx
              • 8371
              #5076
              good for you. the s62 alternator costs stupid money also.
              welcome back holland
              Gigitty Gigitty!!!!
              • Northern
                I like cupcakes & sh!tboxes
                • 5284
                #5077
                Originally posted by FunfGan
                *quote*
                ^ That's a name I haven't seen in a while now.
                Holland too, wow.
                Originally posted by priapism
                Originally posted by shameson
                • ThatOneEuroE30
                  • Dec 2013
                  • 8626
                  #5078
                  Some of you may remember me posting about those old VDO gauges I had. I finally found a use for them.
                  This is just the start. I gotta cut the holes more to get gauges to sit it and cut the hole for the speedo to sit in which is now a clock. I will round the edges of the cedar wood and distress it with the blow torch and then put a clear lacquer over it. And wrap the would in some sheet metal that will get painted and distressed. The gauges will all get wired up to a 9 volt battery with a switch and the voltage gauge will be functioning since it will be a 9 volt system.
                  • ThatOneEuroE30
                    • Dec 2013
                    • 8626
                    #5079
                    Done for the most part.
                    • MrBurgundy
                      R3V Degenerate
                      • Mar 2012
                      • 5616
                      #5080
                      Is holland cool or what?
                      • roguetoaster
                        Biggus Tippus
                        • 7830
                        #5081
                        Missed the opportunity to make it rotary shaped. Will the gauges be operational?
                        • ThatOneEuroE30
                          • Dec 2013
                          • 8626
                          #5082
                          The gauges will light up and the voltage gauge will light up and show voltage
                          • ThatM20Guy
                            • Aug 2014
                            • 600
                            #5083
                            Looks pretty neat!
                            On a side note, are any of you running a brake hardline delete/softline kit? Just curious since I saw chase bays kit.
                            89' 325ix Diamantschwarz/Black rattle can...
                            Insta: r_moose_w
                            Originally posted by flyboyx
                            I imagine her smelling like spoiled milk and having a half inch crust of doodoo circumnavigating her butthole.
                            • Northern
                              • 5284
                              #5084
                              I don't like Chase Bays in general... The fact that they make a single piston brake master cylinder makes me question how much thought or care they put into their products.
                              Oh, and then after multiple people started hating on them, they apparently added this line:
                              A common misconception is to believe this causes a higher risk of failure due to a lack of a back up line should one line fail. Most OEM master cylinders are still single feed internally and have the same assumed “risk” to our Master Cylinder.
                              Apparently they've never even looked at the OE Brake Master Cylinder that they're replacing?
                              Also pretty basic probability to figure out that the chance of failure for both pistons in the OE cylinder is way less than a single.
                              • ThatM20Guy
                                • Aug 2014
                                • 600
                                #5085
                                Huh never thought to look at that but you're totally right. Not sure how they can really miss that...maybe the refer to single feed as in pulling from one reservoir ;D
                                Insta: r_moose_w
