Nonsense Thread
  • Melon
    • Mar 2018
    • 1311
    #11086
    what is the car doing when cold?
    On cold starts is bogs down, hit the gas and it almost stalls out.
    While driving, as soon as I'm coming off the throttle, pulling up at a stop sign, it dies about 1/2 the time.
    Once it's warm, it runs like a champ. I've gone down the list of all the usual suspects, about to pull the DME and see if the sensors aren't getting their signals to the computer.
    I do things.
    • Melon
      • Mar 2018
      • 1311
      #11087
      Originally posted by 2mAn
      Yea I just went through a chunk of the thread... some earlier pics are gone, but all the later ones are there pretty much.
      I shouldn't have looked as Im tempted again to buy it back haha dammit
      Word man. Lots of good stuff.
      Big engine + shitbox + racing Recaros. I'm on-board with that.
      I do things.
      • MrBurgundy
        R3V Degenerate
        • Mar 2012
        • 5616
        #11088
        eh, just part it out
        • Melon
          • Mar 2018
          • 1311
          #11089
          One E30 chassis/body
          Used
          Slightly orange
          Comes with a lot of parts attached.
          $10,000.00
          I do things.
          • 2mAn
            Señior Mod
            • 21085
            #11090
            Used
            Slightly orange
            R3V Carrot of the Month
            $100,000.00
            fixed that for you
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            Make R3V Great Again -2020
            • Melon
              • Mar 2018
              • 1311
              #11091
              I see you put an M3 badge on my car, Danke schon
              I do things.
              • roguetoaster
                Biggus Tippus
                • 7830
                #11092
                Eh, you know what everyone says, BMWs are unreliable, and why would you want to drive an old car anyway? I'll take that scrap off of your hands, and I'll even give you a transverse engine FWD Ford from this millennium, because we know those must be better somehow.
                • Melon
                  • Mar 2018
                  • 1311
                  #11093
                  I appreciate these answers more than the 'CLEAN YOU ICV" responses in technical threads.
                  I do things.
                  • MrBurgundy
                    R3V Degenerate
                    • Mar 2012
                    • 5616
                    #11094
                    • 2mAn
                      Señior Mod
                      • 21085
                      #11095
                      *yer
                      Simon
                      Current Cars:
                      -1966 Blue Boat
                      -1969 Red VW
                      -1986 White BMW
                      -2006 Green Thing
                      • Melon
                        • Mar 2018
                        • 1311
                        #11096
                        Did me a giggle.
                        For the record, I did put some new ones in Saturday, the old ones didn't look great, but weren't fouled. Smelled a bit like gas. Inside of the cylinders looked black and had a little gunk, just evidence of it running rich.
                        I do things.
                        • MrBurgundy
                          R3V Degenerate
                          • Mar 2012
                          • 5616
                          #11097
                          Did me a giggle.
                          I literally just did the same thing..
                          Ended up being my FPR.
                          I always had my suspicions about it, but every time I would pull the vac line off, I wouldn't see any gas, but it was indeed leaking to the intake AND to the return line. My plugs were fouled, but it would backfire, so it was a big WTF to me.
                          I pinched the vac line with some vice grips, then removed it from the FPR with no change to the engine. Put my vacuum pump on it, pulled 10 lbs of vac and it would bleed off pretty quickly.
                          Replaced it, this afternoon actually, and it solved my problem. Also fixed this weird idle issue where I would let off the throttle and it would hunt for a stable idle for a second.
                          • Melon
                            • Mar 2018
                            • 1311
                            #11098
                            I have a new one coming in. Same thing, pulled the vacuum line off, and it ran the same. It also ran the same with both a 2.5 bar and 3.0 bar. Both cheap aftermarket.
                            I also have another set of injections I may swap in.
                            I do things.
                            • roguetoaster
                              Biggus Tippus
                              • 7830
                              #11099
                              The vacuum pump caused the ICV to be cleaned with the fuel in the intake tract...
                              • Melon
                                • Mar 2018
                                • 1311
                                #11100
                                I do things.
