Nonsense Thread
  • Melon
    • Mar 2018
    • 1311
    #11116
    Originally posted by TeXJ
    wow, didn't think the last post I made even was posted
    I tried to repost and the site looked like it was down.
    Same, I got an error twice that my post didn't go through.
    I do things.
    • 2mAn
      Señior Mod
      • 21085
      #11117
      I got the error earlier, but left it alone since I saw so many double posts...
      S2K isnt a bad option if you can find a clean one...
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • Melon
        • Mar 2018
        • 1311
        #11118
        Melon, make sure that purge valve is closing under the throttle body.
        I think those are normally close, so if you take if off and blow through it, no air should be able to pass.
        In theory, an open purge valve will cause a hard cold start.
        Also, make sure your idle/throttle is all set up correctly.
        ***unplug your ICV and adjust the throttle stop screw until your idle gets up to about ~900 rpm. Then, reconnect the ICV and your idle should stabilize at 750 rpm. You may need to adjust your TPS again after the adjustment, since you're going to be changing your "closed" position of the throttle body.
        Thanks man, I never the throttle screw as such. I just did what the Bentley said, it gives a measurement, but I have it set to be slightly open. Enough to see light through. But, that was all done with the the TB off the car.
        I'm going to pull the purge line off, and cap it when I get home.
        See what that does.
        As far as long crank starts, it only does those after I've driven the car, gotten it temp, and then park it for an hour or two. When it's cold it cranks up pretty quickly.
        I do things.
        • Northern
          I like cupcakes & sh!tboxes
          • 5284
          #11119
          The forum seems to be doing this off and on since shortly after the update? Today wasn't the first
          Originally posted by priapism
          Originally posted by shameson
          • roguetoaster
            Biggus Tippus
            • 7830
            #11120
            RIP r3v, long live tit posts!
            • Melon
              • Mar 2018
              • 1311
              #11121
              Found it!
              Pin 45
              No continuity to the blue temp sensor.
              Pin 24 (Ground)
              Tested good.
              Car was warm, sensor was @ 275 ohms.
              I did the idle screw adjustment, and adjusted the TPS, it seemed to help some, but I'll get the temp sensor working before I try to dial in all of that again.
              I do things.
              • TeXJ
                • 1914
                #11122
                Originally posted by Melon
                Found it!
                Pin 45
                Pin 24 (Ground)
                Is good, but not the signal wire.
                I did the idle screw adjustment, and adjusted the TPS, it seemed to help some, but I'll get the temp sensor working before I try to rest all of that.
                This is what I need to check on mine, but mine is an obd1 swapped m52
                1990 325is
                m52b28
                3.73lsd
                g260 (1987 325is 5spd tranny)
                • Melon
                  • Mar 2018
                  • 1311
                  #11123
                  Car starts like a champ now.
                  Fuck yeah!
                  I do things.
                  • roguetoaster
                    Biggus Tippus
                    • 7830
                    #11124
                    Fuck yeah!
                    Yeeeaahhhh boiiiii, got that ICV all cleaned up!!!
                    • MrBurgundy
                      R3V Degenerate
                      • Mar 2012
                      • 5616
                      #11125
                      Fuck yeah!
                      Yeet Haw
                      Where was the problem exactly? broken wire? C101?
                      • TeXJ
                        • 1914
                        #11126
                        Yeah what was the actual issue?
                        1990 325is
                        m52b28
                        3.73lsd
                        • 2mAn
                          Señior Mod
                          • 21085
                          #11127
                          Yes and please explain it using a meme
                          Simon
                          Current Cars:
                          -1966 Blue Boat
                          -1969 Red VW
                          -1986 White BMW
                          -2006 Green Thing
                          • MrBurgundy
                            R3V Degenerate
                            • Mar 2012
                            • 5616
                            #11128
                            Come on, melon, tell yah boys wuzzup
                            • TeXJ
                              • 1914
                              #11129
                              It's Friday, you aint got no job...you aint got crap to do!
                              1990 325is
                              m52b28
                              3.73lsd
                              • Melon
                                • Mar 2018
                                • 1311
                                #11130
Name:	Shaq Tries to Not Make a Face 22112019200513.jpg
                                I do things.
