2003 330i terrifying vibrations at 65.
  • slammin.e28
    שמע ישראל
    • 12054
    Seriously. Feels like the car is going to fucking fly apart. It's got 150k highway miles. 5sp car. Sometimes it does it taking off into a turn in 2nd gear but not always.
    I'm at a loss. Guibo? Ball joints? I just did the lollipops. Car is basically fine until you hit 65 then it's death.
  • Kershaw
    • 11822
    rear subframe?
    dont e46s have a massive failure point in the trunk/rear subframe mounting location? for it to be fixed, plates have to be welded in.
    don't die. park it until you figure it.
    AWD > RWD
    • slammin.e28
      שמע ישראל
      • 12054
      I thought that was just a huge clunk on hard takeoffs? No clunking going on. Just a death shudder at 65. Goes away at 70.
      • Ratbastage
        • Dec 2010
        • 77
        As in death wobble in the wheel?
        • Kershaw
          • 11822
          if it's starting to rip apart, the resonance could easily make it shudder at certain speeds.
          AWD > RWD
          • trippmann
            • Dec 2012
            • 118
            check your tie rods, i had a shudder around that speed and when i replaced mine it went away completely.
            Originally posted by unloadedak
            It's brand new. I've gripped the shaft a couple times and that's about it.
            • Swanny
              • Mar 2012
              • 2834
              Yeah MAJOR fail in the rear subframe mounting points. But kinda sounds like a wheel balance/ tire issue. Just had a set of tires delaminate on me and that was a blast to find out.
              Swap your wheels and see whats up?
              Swanny!
              SUCKERS.
              • Mlarsen
                • 4082
                I bet you 5 bucks it's a seperated tire.
                • dannyyisntt
                  • 3141
                  Your car is having cocaine withdrawals
                  • vert_this
                    • Feb 2012
                    • 395
                    yeah I go with a busted belt in a tire too..
                    • slammin.e28
                      שמע ישראל
                      • 12054
                      Huh. Didn't even think of a busted belt in the tire. They are getting pretty cupped. Car needs an alignment hardcore but I never get the car to work since the gf drives it 100 miles a day.
                      Ill try to throw it on the lift tomorrow and see if I can see anything obvious going on under it. This thing has been driving me nuts lately.
                      • Stiggy
                        • Nov 2012
                        • 40
                        Throwing another dollar on the pile. I'm betting it's tires out of balance / out of round.
                        • redsubdivisions
                          • Feb 2011
                          • 1762
                          Tires most likely. If it was the rear subframe (which I highly doubt), that rear end would clunk. You would hear and feel it too lol
                          1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
                          2012 Passat TDI - DD Duty
                          2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
                          • Northern
                            I like cupcakes & sh!tboxes
                            • 5265
                            Csb? Would be nice if you could pinpoint what part of the car feels like its blowing up
                            Originally posted by priapism
                            Originally posted by shameson
                            • Victell
                              • 1083
                              no-cost option: dont drive 65
