Drill Press Quill/Spindle Bearing Installation Question
  • mrsleeve
    • Mar 2005
    • 16386
    right its a high pressure lube, but your right it will foul when you get it conditions right for it to start bonding to surfaces unevenly. Hence as I understood it low temp, low speed, low pressure bearings.
    Originally posted by Fusion
    William Pitt-
    • bmwman91
      • Oct 2004
      • 3134
      I got the motor back together tonight. The 6203 and 6204 bearings were an easy fit. I tossed them into the oven at ~190F for 15 minutes and left the rotor at room temp. They slid right into place and grabbed about 3 seconds later. The fit into the end caps of the motor was even easier. Some very light taps with a soft rubber mallet got everything seated. After that, I soldered in the new 400mF start cap and reinstalled the centrifugal switch for the cap circuit. It fired right up and hummed pleasantly pleasantly on the bench.
      Hopefully on Friday I will get to the rest of the bearing assemblies in the quill/spindle. It looks like a little heating makes these things a lot easier!
      Thanks again for all of the help.
      Transaction Feedback: LINK
      • Kershaw
        • 11822
        Originally posted by bmwman91
        STP? Bruh, that is not a locally-sourced, organic, artisanal lubricant from a 51% woman-owned company. Putting that on a tool from Santa Cruz would be a micro-aggression against its gender identity
        AWD > RWD
